204
  1. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jul 10, 2018
  2. pablofg1978
    Spanish POC Assistant Head Moderator Jul 10, 2018
  3. G_gaganpreet_singh
    Gingerbread Jul 10, 2018
    G_gaganpreet_singh , Jul 10, 2018 :
    sorry to post this problem here.
    I don't get notified by yowhatsapp when I get a new msg can you tell me how can I fix it?
  4. Fwosh
    Eclair Jul 10, 2018
    Fwosh , Jul 10, 2018 :
    I've cleared my Google play services cache and then did a cache wipe in recovery mode. The predicted battery life has improved massively. Let's see if It comes through...
    Borjiskan55 likes this.
  5. Justinnov23
    Justinnov23 , Jul 10, 2018 :
    can we do this once a week??
  6. Justinnov23
    sir this cache wipe on recovery mode once a week is safe or not??
  7. Edenhazard10
    Froyo Jul 10, 2018
  8. Fwosh
    Eclair Jul 10, 2018
    Don't see why not
  9. pablofg1978
  10. Catalin_Buzescu
    Jelly Bean Jul 10, 2018
    Catalin_Buzescu , Jul 10, 2018 :
    It doesn't harm. Usually, people here smarter than me reccommend wiping cache only once after updating. I find myself doing it more often, maybe twice a month. In my opinion, it helps.
    Justinnov23 likes this.
  11. meena0438
    Donut Jul 10, 2018
    meena0438 , Jul 10, 2018 :
    I am not using wifi in oneplus 6 in india but battery drain issu Automatically drain battery in 7 to 10% without use wifi pls suggest and solved this problem
    Show this image wifi use 6% but i am not use
  12. NeVeR_SeTTLe
    NeVeR_SeTTLe , Jul 10, 2018 :
    Can you post your usage also? The graph version?
  13. soumgroy
    Froyo Jul 10, 2018
    soumgroy , Jul 10, 2018 :
    os5.1.8 does offer a comparatively quick discharge of battery in standby. it's true, and lots of folks out there are facing same. I myself hardly get 3/4 hours of sot. it's not upto my satisfaction at all.
  14. meena0438
    Donut Jul 10, 2018
    yes
  15. meena0438
    Donut Jul 10, 2018
  16. NeVeR_SeTTLe
  17. U1531247685408
    Cupcake Jul 10, 2018
    U1531247685408 , Jul 10, 2018 :
    Same here. Although the battery is not an issue and gives me around 6.5 hours of SOT always. That bit is annoying sometimes.
  18. meena0438
    Donut Jul 10, 2018
  19. NeVeR_SeTTLe
  20. meena0438
    Donut Jul 10, 2018
    what is roungh in my screenshot same here but i am not use wifi but scroll down 6 no show wifi usage ok
