204
  1. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jul 10, 2018
  2. 27itachi
    Gingerbread Jul 10, 2018
    27itachi , Jul 10, 2018 :
    5h battery life isn't that bad
  3. Tom_lecter
    Ice Cream Sandwich Jul 10, 2018
    Tom_lecter , Jul 10, 2018 :
    WiFi scanning maybe ON in your device. Please turn it off.
  4. pablofg1978
    Spanish POC Assistant Head Moderator Jul 10, 2018
    pablofg1978 , Jul 10, 2018 :
    Thread merged
  5. Onejensen
    Cupcake Jul 10, 2018
  6. svnni
    svnni , Jul 10, 2018 :
    Not necessarily. While there seems to be more issues reported on the a6000, there have been more sales of this version and a generally a more active community in India. So it's difficult to say.
    The battery drain issue does seem to be reported on the 6003 too, not sure about the heating issue.
    My battery drain went down a bit on my 6003 with 5.1.8. where mostly the screen seems to drain more battery than prior to the update. It's still not as hard as some people reported. I still have well over 7h sot but it's considerably less than on 5.1.7.
    Hope this answers some questions. This is just my take from reading the forum.
  7. Dobger24
    Cupcake Jul 11, 2018
    Dobger24 , Jul 11, 2018 :
    for yr first part of sentence. WHY?
    Second part. Make sense batman
  8. Justinnov23
    Gingerbread Jul 11, 2018
    Justinnov23 , Jul 11, 2018 :
    there's a solution..go to settings.select wifi option and select WiFi preferences.In that deselect Smart WiFi switcher and Scanning always available..Also next go to settings and select Location..In That Select three dot menu on upper right menu of the screen...Then deselect wifi scanning and Bluetooth scanning..Hope it fixes...
    Drsj likes this.
  9. tcntad
    tcntad , Jul 11, 2018 :
    There goes my hopes..Well Im on 5.1.7 and Ill stay for awhile. Im having enough drain there is..
  10. G_gaganpreet_singh
    G_gaganpreet_singh , Jul 11, 2018 :
    go to WiFi>WiFi preference>advanced>trun off scanning always available
    Drsj and Sc1ence_G like this.
  11. OPOBEAST
    Honeycomb Jul 11, 2018
  12. OPOBEAST
  13. Drsj
    Gingerbread Jul 12, 2018
    Drsj , Jul 12, 2018 :
    posting a pic, should help. here what I want to point is when my phone was not being used or screen was locked there was constant awake cycle going on. which lead to heavy discharge at night, standby drain, so yesterday what I tried was :
    settings- advanced- then scroll down to recent app management there I chose - deep clear.
    now dose mode seems to be working. plus less standby drain. awake and screen on were not in sync. but still getting WhatsApp updates etc.
    other thing is been telling in WiFi settings turn off WiFi preference- WiFi scanning always turn that off.
    to reduce battery drain majorly. hope this helps as it did to me.
    sorry don't have before screen shots.
    but even before got 6 to 8 hours of sot. will post updates today... not bored at work
    Justinnov23 likes this.
  14. Drsj
    don't use auto brightness big battery drain. turn off things you don't need. adding a more recent pic 1531369440684.jpg
  15. M1528739170147
    Eclair Jul 12, 2018
  16. Drsj
    before doing that see above posts for WiFi settings, read my tweak, turn off adaptive brightness, even Bluetooth, GPS,nfc when not in use. clear cache in settings-storage and clear cache after turning off the phone. you can search how to is easy give it a try..
  17. Drsj
  18. M1528739170147
    Eclair Jul 12, 2018
    M1528739170147 , Jul 12, 2018 :
    i did all that last night and here is the result so far
  19. Drsj
    take long screenshot, plus double tap battery in this settings to show further usage
  20. M1528739170147
    Eclair Jul 12, 2018
    here
