235
  1. Drsj
    Gingerbread Jul 12, 2018
    Drsj , Jul 12, 2018 :
    I think it's fine, you are your day with 80 something percentage, your usage will be around 5.5 to 6 hours. did you try the recent app management
  2. M1528739170147
    Eclair Jul 12, 2018
    M1528739170147 , Jul 12, 2018 :
    It is set to "normal clear"
  3. Drsj
    charge to do clear and see a day or 2 usage
  4. Justinnov23
  5. Drsj
    yes sorry for the typo
  6. M1528739170147
    Eclair Jul 12, 2018
    Okay thanks a ton.. will try that for a couple of days
  7. Justinnov23
    Justinnov23 , Jul 12, 2018 :
    bro by enabling deep clear any problems in notification??
  8. Justinnov23
    also what is the use of enabling deep clear instead of Normal clear??
  9. Drsj
    no getting all, even when phone locked, unless you have turned off notification for an app, try for few days. no problems here
  10. Drsj
    with deep clear, haven't closed any app, plus closing and opening drains battery. all apps running in background.
  11. Drsj
  12. M1528739170147
    Eclair Jul 12, 2018
    yes did dark theme just now
    and i have this as my wallpaper
    Drsj likes this.
  13. blackscreener
    Donut Jul 12, 2018
  14. Drsj
    not clear. could you break the screen shot and post. take screen shot in section.
    any suggestions from your side
  15. blackscreener
    Donut Jul 12, 2018
  16. Drsj
    blackscreener likes this.
  17. Drsj
    bro have got 9.5 hours and today should be the highest record, cheers to 1 plus
  18. blackscreener
    Donut Jul 12, 2018
    Drsj likes this.
  19. blackscreener
    Donut Jul 12, 2018
  20. Justinnov23
    wow....any tips can u suggest for such SOT!!
