235
  1. MD_18
    Honeycomb Jul 16, 2018
    MD_18 , Jul 16, 2018 :
    Don't compare heating problem with the apps inability to support19:9 ratio. Also im not complaining and you aren't a developer so stop playing detective about the problems i have.
  2. Prcko
    KitKat Jul 16, 2018
    Prcko , Jul 16, 2018 :
    so how you want to solve this problem?
  3. Shajith mohamed
    Cupcake Jul 16, 2018
    Shajith mohamed , Jul 16, 2018 :
    battery draining more than how t used to b in previous update hope new update will be released soon
    but the heating problem while gaming and poor call quality is really annoying
  4. G_gaganpreet_singh
    Gingerbread Jul 16, 2018
    G_gaganpreet_singh , Jul 16, 2018 :
    yes just long press the number you want to block and then you can block it easily but before posting just search for your answer
    Justinnov23 likes this.
  5. Ilanvarman
    Ilanvarman , Jul 16, 2018 :
    was just playing pubg in oneplus 6 8gb ram and it's getting heated up so fast. Is this normal?
  6. pablofg1978
    Head Moderator Head Moderator Jul 16, 2018
    pablofg1978 , Jul 16, 2018 :
    Thread merged
  7. G_gaganpreet_singh
  8. kchan9
    Donut Jul 16, 2018
    kchan9 , Jul 16, 2018 :
    I've tried doing that and with the "Deep Clear" under Recent App Management, my emails do not get alerted although all the priority setting is at "high". There are certain apps that I will not receive notifications from. So what is the point of this if notifications aren't coming through? I think OP team has to take a look into the battery drain. I'm getting 3.5 hours of screen time with normal usage
  9. taiyou94
    Froyo Jul 16, 2018
    taiyou94 , Jul 16, 2018 :
    thats not the peoblem with me, i am also using the DEEP CLEAR. And sorry but i got the screen on time around 7 hours, and trying to set the things to get around 8 hr. min. SOT[e]1f60a[/e]
    Drsj likes this.
  10. taiyou94
    Froyo Jul 16, 2018
  11. furqanafzal
    Donut Jul 16, 2018
    furqanafzal , Jul 16, 2018 :
    Here is the tip and you can save your battery life for long time.
    Don't charge your phone 100%
    keep it between 40% to 80%
    it always helped me. i hope it will help u too. [e]1f60a[/e]
    Soham_Maiti likes this.
  12. discofiddan
    discofiddan , Jul 16, 2018 :
    There are alot of information we dont know about how you optimize your phone. background data, screen strength etc etc. ive had iPhone 4, 5, 6, and now OnePlus 6 and couldnt be more happy about the batterytime noticable with the big screen, Speed and quality you get. Try play around with settings and optimize it and compare it later is my tip.
    sorry for bad English tho [e]270c[/e]
    edit: dont do like previous reply say, quickest thing to kill a battery is to microcharge a phone every day, you should let it die from time to time and Always charge full.
    here is my battery, not used it to much here tho since last charge, mostly spotify running in background and random checking apps.
  13. ani150101
    Froyo Jul 16, 2018
  14. kchan9
    Donut Jul 16, 2018
    When you're using Deep Clear, do you have any problem with receiving notifications from Emails and etc? The notifications from Whatsapp and SMS messages are fine but again, I'm not sure why my emails don't come through. I'm using the Outlook app as my email preference.
    Thank you!
  15. taiyou94
    Froyo Jul 16, 2018
    i dont have issues with mails, i am using only Gmail, if u r not very much worry about the battery and SOT, then u use Normal Clear. Its Ok, well u clear the app from Recent Buttons or clear your Ram Manually. Since app open in Background eating up RAM and thats also goes for Battery.
    hope it'll helps, thank you.
  16. Pirati81
    Eclair Jul 16, 2018
    Pirati81 , Jul 16, 2018 :
    Overheating is the only issue I am not concerned with my oneplus 6. It does not overheat even after playing graphic intensive games such as real racing and need for speed. The problem you are describing should be a software issue.
  17. G_gaganpreet_singh
    Gingerbread Jul 17, 2018
    G_gaganpreet_singh , Jul 17, 2018 :
    Drsj
    svnni
    Cheers! Gonna try this. Seem from today it seems to improve battery life on my end.
    last night, know would have gone to 10hrs SOT​
    I don't know might be you are faking that SOT, your battery graph shows that you are charging your phone side by side that's the reason you are getting 9.5hrs of SOT
  18. U1531768352611
    Cupcake Jul 17, 2018
    U1531768352611 , Jul 17, 2018 :
    what about high graphic game like pubg. I played on the highest settings possible and the phone heated within 20-25 mins
  19. Rohan Mane
    Froyo Jul 17, 2018
  20. hotmomma
    Ice Cream Sandwich Jul 17, 2018
    hotmomma , Jul 17, 2018 :
    PUBG isn't optimised (enough) yet for mobile gameplay so give it some time
