193
  1. xnutzii Lollipop Aug 2, 2018
    xnutzii, Aug 2, 2018 :
    That's probably normal, I don't play this game, tho it seems like it has some kind of intense graphics.
  2. benulin1 Honeycomb Aug 2, 2018
  3. xnutzii Lollipop Aug 2, 2018
    Yeah, how warm/hot does it get? Use some apps like CPU-Z or Kernel Toolkit. Then report back using the "reply" option.
  4. Navneet_Bhaskar Froyo Aug 2, 2018
  5. G_Anuj_gupta_hlyq Cupcake Aug 2, 2018
  6. xnutzii Lollipop Aug 2, 2018
    In which case? App? Ambient temperature?
  7. Callme_Bi3 Froyo Aug 2, 2018
  8. Navneet_Bhaskar Froyo Aug 2, 2018
    Navneet_Bhaskar, Aug 2, 2018 :
    I was running regular apps, so i switched of my mobile and started after 5 min. It got normal.
    Its not that frequent.
  9. pablofg1978 Spanish POC Assistant Head Moderator Aug 2, 2018
    pablofg1978, Aug 2, 2018 :
    Thread merged
  10. LeKeiser Froyo Aug 2, 2018
    LeKeiser, Aug 2, 2018 :
    I'm sorry but could you give me your source when you say a factory settings doesn't wipe the cache as well when you do it ? Because since the phone is back to the factory settings, meaning exactly how it was when you bought it, well the cache is... Empty.
  11. W1nd Gingerbread Aug 2, 2018
    W1nd, Aug 2, 2018 :
    this is the common problem with oneplus 6 . i play pubg on high setting and it start heating like anything . and than lagg and chopping
  12. D1533233717444 Cupcake Aug 2, 2018
    D1533233717444, Aug 2, 2018 :
    1. do you play with a charger plugged in?
    2. So you enable game mode Everytime you play?
    I play pubg, rr3, and clash Royal on my 1+6 and the only time I have issues with heat is when I either have my phone charging at the same time or forgot to enable game mode.
  13. V1532632639734 Eclair Aug 2, 2018
    V1532632639734, Aug 2, 2018 :
    Hello Everyone,
    as we all are pretty much aware that OnePlus 6 has started creating so many problems right after the latest oxygen OS update. major concern being the battery backup and drain issues.
    I would want your suggestions to whether return the OP6 that I bought a week ago and wait for OP6T to arrive all the bugs fixed before hand. OR shuold I wait for the next update in a hope that the battery drain problem will be fixed.
    your suggestions are appreciated. Thanks in advance
  14. pablofg1978 Spanish POC Assistant Head Moderator Aug 2, 2018
    Thread merged
  15. Deactivated User Aug 2, 2018
  16. Deactivated User Aug 2, 2018
  17. V1532632639734 Eclair Aug 2, 2018
    the battery drain problem. I have mentioned it above in the thread
  18. Deactivated User Aug 2, 2018
  19. V1532632639734 Eclair Aug 2, 2018
  20. Deactivated User Aug 2, 2018
