255
  1. asaputrosnk
    Gingerbread Aug 2, 2018
    asaputrosnk , Aug 2, 2018 :
    i often get notification like pic below saying that chrome browser is draining battery when i did not open the app , are there any way to prevent it beside uninstalling it
    i tried to optimize battery usage but i can't find chrome in battery optimation menu
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 2, 2018
    Artemus , Aug 2, 2018 :
    What do you got going on in Chrome?
  3. asaputrosnk
    in chrome just browsing
    sometime i got notification when i just few minutes after turn on the device
  4. nyzproof333
    KitKat Aug 2, 2018
  5. asaputrosnk
  6. toastytoast1234
    Marshmallow Aug 2, 2018
    toastytoast1234 , Aug 2, 2018 :
    Do you not think it might use some battery when loading data in the background, or do you suppose OP have invented a perpetual energy machine to power the OP6?
    nyzproof333 likes this.
  7. asaputrosnk
    toastytoast1234
    not sure either..
    btw no battery optimazition for all google app.
    i can't find playstore, youtube , inbox, gmail ,map, duos, hangout in battery optimazition menu, so it might have something to do with google privilege given by op , just guessing though..
    google explicitly can do whatever they want in one plus, even draining your battery
  8. asaputrosnk
    Gingerbread Aug 3, 2018
    asaputrosnk , Aug 3, 2018 :
    one more detail i had turn off background process in developer menu but batt chrome draining still happening
  9. asaputrosnk
    turning off background data , won't stop wifi background accsess
    battery may still drained
  10. toastytoast1234
    Marshmallow Aug 3, 2018
    toastytoast1234 , Aug 3, 2018 :
    I don't think anybody cares at this point.
    Deactivated User and nyzproof333 like this.
  11. asaputrosnk
    yup but people often complaint about battery draining
  12. Deactivated User
    Aug 3, 2018
  13. pablofg1978
    Head Moderator Head Moderator Aug 3, 2018
    pablofg1978 , Aug 3, 2018 :
    Thread merged
  14. RajJhamtani1
    Eclair Aug 3, 2018
    RajJhamtani1 , Aug 3, 2018 :
    I don't think there is any solution for prevention feom battery draining!
    let's just hope OnePlus gives us a new update regarding that!
    #fingerscrossed
  15. W1530387847182
    Cupcake Aug 3, 2018
  16. Kleiger
    Cupcake Aug 3, 2018
    Kleiger , Aug 3, 2018 :
    try turning off your 4g data. also talk tell your carrier see if they can do anything.
  17. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 3, 2018
    Artemus , Aug 3, 2018 :
    Wow, so much detail...
  18. Artemus
    Battery drainage is usually due to either user error or bad signal. Sometimes both.
  19. kokjoo89
    Froyo Aug 3, 2018
    kokjoo89 , Aug 3, 2018 :
    I just get my new phone few day ago. Out of the box load with OOS 5.1.8, I update it to 5.1.9
    now the issue is the battery drain from 100 to 79 over the night. is this normal? I'm yet to set my SIM into it.
  20. Andyreww
    Cupcake Aug 3, 2018
    Andyreww , Aug 3, 2018 :
    Give your phone some time to adjust to the update and in the meantime switch off your WiFi and gps while sleeping. And if the situation persists after some days then maybe you got a faulty device, ask for a replacement.
    Artemus likes this.
