200
  1. ngydat
    KitKat Aug 10, 2018
    ngydat , Aug 10, 2018 :
    Posting a screenshot of your battery stats 11 minutes after unplugging your charger means nothing. You guys should stop being so paranoid over the battery.
    soROCKin88 and pranav.bhosle12@ like this.
  2. Shshank Vishwa
    Honeycomb Aug 10, 2018
  3. izzykasha
    Lollipop Aug 10, 2018
    izzykasha , Aug 10, 2018 :
    the issue here is user knowledge.
    Let your phone now run to 10% and post battery stats
    soROCKin88 and ngydat like this.
  4. TANMAY BISWAL
    Eclair Aug 10, 2018
    soROCKin88 likes this.
  5. G1533308668880
    Cupcake Aug 10, 2018
  6. Ravi9390
  7. Liehjan
    Liehjan , Aug 10, 2018 :
    What do you mean with "current leakage" ?
    izzykasha likes this.
  8. izzykasha
    your phone is leaking !!!! damn
    honestly provide temperatures max, what you are doing at the time and battery stats or refer to the good pinned threads about battery and heating that are available by using the forum Search !
  9. Ravi9390
    Ravi9390 , Aug 10, 2018 :
    while charging a light current can be feel near by rear camera. also heating issue is on top of phone or near by rear camera and alert slider.
  10. izzykasha
    if you use your phone whilst charging you will get heat and also if you start charging with the phone already hot it won't cool down whilst charging.
    this is normal
  11. Gameslayer
    Gingerbread Aug 10, 2018
    Gameslayer , Aug 10, 2018 :
    meaning of current leakage ??are u saying that it's gives u light electric shok ??
  12. Gameslayer
  13. Elaitscha
    Eclair Aug 10, 2018
    Elaitscha , Aug 10, 2018 :
    Not totally true. Yeah you're right that you should never charge your phone until 100% and then let it decrease to 0% ..that's very bad for battery. Keep it between 15/20% and 85-max.95% then you should have a long battery live.
    BUT: You should charge your phone to 100% at the first time due to the fact that your phone needs to calibrate the battery. So when you get the device charge it ones or twice until 100% (let it go down to the 20% how I said) and then keep it up not going over max. 95% :)
    B1533630732885 likes this.
  14. Ravi9390
    yes
  15. B1533630732885
    B1533630732885 , Aug 10, 2018 :
    yeaaa that's what i was really trying to say!
    Elaitscha likes this.
  16. Gameslayer
    try to change charging point and check also try to swipe charger or cable and check it's possibly faulty cable issue
  17. Ravi9390
  18. Gameslayer
    go to service centre asap there is possibility of short circuit do not use phone till time ASAP visit service centre if ur device is in Amazon replacement policy replace asap
  19. Ravi9390
  20. brossovitch
    brossovitch , Aug 10, 2018 :
    it used to work a day ago... now what? Chrome?
