255
  1. Terryruiz
    Ice Cream Sandwich May 27, 2018
  2. outpin
    Honeycomb May 27, 2018
    outpin , May 27, 2018 :
    Maybe we'll have a bigger one on the 6T.
    ChrisFR06 and Terryruiz like this.
  3. Terryruiz
    Terryruiz , May 27, 2018 :
    he probably got everything off in background
  4. V1527440053381
    Cupcake May 27, 2018
    V1527440053381 , May 27, 2018 :
    no 1 got anything off in the baground. either inside or outside with all lights on when you change the mode to slow motion the screen is getting dark.
  5. walpanmad
    Froyo May 27, 2018
    walpanmad , May 27, 2018 :
    if you received using slow motion videos in low light conditions then it will naturally flicker. use this feature outside
  6. stratege1401
    Froyo May 27, 2018
    stratege1401 , May 27, 2018 :
    well, I won't buy a one6T, so I guess I only care my battery would be larger.
    I passed my one5 to my wife and I don't planned to spend money for the next two years at last.
    So, one6T or one7 are out of my mind so far
    siamer likes this.
  7. MentalDraco
    Marshmallow May 27, 2018
    MentalDraco , May 27, 2018 :
    5T
    2020amolg likes this.
  8. Marcori
    Donut May 27, 2018
    Marcori , May 27, 2018 :
    I guess there still something to improve considering it's not even a week it is available
    Darwin94 likes this.
  9. Darwin94
    Gingerbread May 27, 2018
    Darwin94 , May 27, 2018 :
    I agree with you. Maybe some future updates can totally improve certain aspects of the phone including the battery.
    ChrisFR06, Terryruiz and Marcori like this.
  10. antidanis
    antidanis , May 27, 2018 :
    Everything seems great with normal usage. The only thing strange for me is my phone uses like 25 percent battery on idle while I sleep. If I go to bed with 75 percent, I will wake up 8 hours later with 50. It only used to go down less than 10 percent on the 5T vs 25 percent on the 6. Definitely has something to do with the OS because the apps and processes I'm using are exactly the same.
  11. Terryruiz
  12. Terryruiz
  13. Terryruiz
    CNET 27, 2018 ..... that the OnePlus 6, poops out about an hour and a half sooner than last November's OnePlus 5T, which has a battery with the exact same capacity as the OnePlus 6: 3,300mAh. What gives?
    When an hour and a half can make all the difference between having connection or not when you're out late, this battery backsliding is a big deal.
    It's that the OnePlus 6, poops out about an hour and a half sooner than last November's OnePlus 5T, which has a battery with the exact same capacity as the OnePlus 6: 3,300mAh. What gives?
    When an hour and a half can make all the difference between having connection or not when you're out late, this battery backsliding is a big deal !!
  14. Terryruiz
  15. Terryruiz
    CNET 27 MAY 2018
    Patrickim2147 likes this.
  16. 2020amolg
    2020amolg , May 27, 2018 :
    Battery is big with the 3300 mAh battery. There is probably some software issues that is draining the battery to fast which OnePlus needs to fix.
    Tom_Com_01 likes this.
  17. Terryruiz
    2020amolg
    Battery is big with the 3300 mAh battery. There is probably some software issues that is draining the battery to fast which OnePlus needs to fix.​
    it's too small for a 6.3 screen ...same as all there 5.5 screens ...so obvious
  18. Marcori
    Donut May 27, 2018
    There's surely something they will improve. Consider that OP6 has a Snapdragon 845 which consumes much less
  19. Terryruiz
  20. 2020amolg
    I understand that but the OnePlus 5T had been pretty good with battery as well and that has 6.01" screen, so I don't think it is a screen size issue but a software issue.
