256
  1. Deactivated User
    Aug 19, 2018
  2. karan.r.deshmukh
    Cupcake Aug 19, 2018
    karan.r.deshmukh , Aug 19, 2018 :
    okay Thanks for clarifying buddy!!!! but usually I can see a drastic drain even without hight SOT
    I have also used OP5 but I didn't saw that fast battery draining
    any ways thanks all for Answering my post.....
  3. Situation
    Eclair Aug 19, 2018
  4. DARSHANING
    Donut Aug 19, 2018
  5. E1533399462584
    Eclair Aug 19, 2018
    E1533399462584 , Aug 19, 2018 :
    sometimes, recalibrating helps. at least that's what I do to my 5T which is after 8 months of heavy use, the battery is still top notch. but of course that includes battery safe practices and what not. but if you really see it as an issue, i suggest going to your OP store and have it checked out
  6. pablofg1978
    Head Moderator Head Moderator Aug 19, 2018
    pablofg1978 , Aug 19, 2018 :
    Thread merged
    Please use the search before creating a new thread
  7. pablofg1978
    Thread merged
  8. Situation
    Eclair Aug 19, 2018
    Situation , Aug 19, 2018 :
    9 hours+ SOT on oneplus 6!!!
    Hi everyone, before you get sceptical check the attachments.
    Im a sucker for battery if there is a term to describe my using pattern it will be A MASSIVE user.
    I finally got the recipe after a termendas amount of attempts and trying different settings and apps. But now I can proudly say i earned it.
    My sitting for this was as follows :-
    1- Auto screen brightness (off).
    2- Night mode (always on) - my personal preference.
    3- Greenfy app (hibernating all rarely used apps).
    4- pixel filter app (this thing really works) set to 50%.
    5- Stock battery saver on (it doesn't affect performance).
    6- Total ram speed booster (auto kill every 1 hour).
    Note :
    1-pixel filter only works with AMOLED panels
    2- the ram management in the oneplus is odd it tends to keep a lot of apps in the ram no matter what u do(so if u rarely use an app just uninstull it)
    3- I didn't face any lag whatsoever or performance compromise. (smooth and sexy as always)
    4- I find the battery summery is not that accurate as I used a lot of YouTube streaming (3 hours +) and (45 mints PUBG gaming - full resolution ) add on that (3 hours of instgram) all that while listening to music on Spotify on my blutooth set (which is oddly did not show in battery summary), and 2 hours of browsing (trying to find the best protection case for my mighty oneplus 6).
    5- here is a tip which I'm using with Facebook but not instgram (cuse Facebook apps suck big time at battery managing) but u can use it with Manny other apps (which is creating a shortcut with chrome browser on home screen its very smooth thou)
    6- the recent update is a juice theft.
    Ps:
    please don't believe me, try it and thank me later.
    make sure to come back and comment so everyone knows that this is legit.
    On A6000, oxygen 5.1.9! Screenshot_20180819-202900.jpg Screenshot_20180819-202906.jpg Screenshot_20180819-202900.jpg Screenshot_20180819-202906.jpg
    Geo36089 likes this.
  9. Deactivated User
    Aug 19, 2018
  10. nin1+6
    Donut Aug 19, 2018
    nin1+6 , Aug 19, 2018 :
    I have been testing mine and so far the following things below that I've back read worked for me to better battery life or I should say less drain with heavy use and phone idle time.
    1. apply dark theme and set wall paper to black with center logo of little white.
    2. cleared all data and cache of apps installed specially Google apps and disable those I don't use.
    3. disable face unlock and stick with from finger print.
    4. remove Geo location of my Home address that's keeping unlock when at home.
    5. drain battery to 15% and full charged using dash charger.reboot phone.
    6. disable Google photos sync through app and account settings.
    7. disable Google drive sync and Gmail sync.
  11. nin1+6
    Donut Aug 19, 2018
  12. nin1+6
    Donut Aug 19, 2018
  13. Ranjith0512
    Donut Aug 19, 2018
    Ranjith0512 , Aug 19, 2018 :
    phone is getting hot after i play pubg.This has started after once i updated to 5.1.11.
  14. H1520937712804
    Donut Aug 19, 2018
  15. Sourabh2503
    Gingerbread Aug 19, 2018
  16. Deactivated User
    Aug 19, 2018
  17. Dexxagon
    Honeycomb Aug 19, 2018
  18. As.sriniv
    Froyo Aug 19, 2018
    As.sriniv , Aug 19, 2018 :
    after update my oneplus 6 version 5. 1. 11 myself my phone battery is draining very quick any other ideas to rescue my battery thank you
  19. Sourabh2503
    Sourabh2503 , Aug 19, 2018 :
    Batterly level decrease very fast
  20. pablofg1978
    Thread merged
