256
  1. pablofg1978
    Head Moderator Head Moderator Aug 19, 2018
    Sourabh Khatavakar likes this.
  2. Deactivated User
    Aug 19, 2018
  3. Deactivated User
    Aug 19, 2018
  4. Sourabh2503
    Gingerbread Aug 19, 2018
  5. Deactivated User
    Aug 19, 2018
  6. Sourabh2503
    Sourabh2503 , Aug 19, 2018 :
    means i dont understand
  7. Deactivated User
    Aug 19, 2018
  8. Sourabh2503
  9. sreenandkrishna
    Donut Aug 19, 2018
    sreenandkrishna , Aug 19, 2018 :
    I am getting exceptionally better battery backup after the 5.1.11 update. I am really glad to say op 6 software te did a wonderfull job.
  10. G_Mohammed_Siyavul_Halik
    Froyo Aug 19, 2018
    sreenandkrishna likes this.
  11. sreenandkrishna
    Donut Aug 19, 2018
  12. E1534514711022
    Cupcake Aug 19, 2018
  13. E1534514711022
  14. xnutzii
    Lollipop Aug 19, 2018
    xnutzii , Aug 19, 2018 :
    No, it hasn't. It's just your imagination. The phone is working hard at playing pubg, a very very badly optimized game, so you have to expect the phone to get warm/even hot. That's just how Physics work. Even the new note 9 with it's "water carbon cooling" will get hot, (since well... Hopefully i won't destroy anyone's dream, but it's just a gimmick.) because it's working hard to push these graphics and the whole map has to render through the cpu, so it's not just after the damn update.
  15. Ranjith0512
    Donut Aug 19, 2018
    Ranjith0512 , Aug 19, 2018 :
    Thank you for making me realise that it was just my imagination.But while playing the same game before,My phone never heated up . Doesn't that mean there is some issue with this particular update.
    Please correct me if i am wrong.
  16. xnutzii
    I won't correct you, since I wrote the whole needed information before. The phone heats up, because it's physics. Don't worry, it's totally normal behavior and maybe the update just has a different power plan and let's the cpu have full performance mode while gaming. Don't worry.
  17. OnePlus3577
    Eclair Aug 19, 2018
    E1534514711022 likes this.
  18. OnePlus3577
    Eclair Aug 19, 2018
    OnePlus3577 , Aug 19, 2018 :
    and you are using WiFi not Mobile data connection. if you use mobile data then u will face 5-6 SOT
  19. E1534514711022
    E1534514711022 , Aug 19, 2018 :
    rohit4577
    and you are using single sim. and on wifi. use two sim cards and use mobile data not wifi. then you will have 5-6 hrs SOT.​
    Sorry, I'm new. Wanna learn more about this One Plus.
    I got inspire from the idea like the community of people help each other.
    Thanks for tipa
    peace
    Never Settle[e]1f498[/e][e]1f498[/e]
  20. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 20, 2018
