255
  1. Terryruiz
    Ice Cream Sandwich May 27, 2018
  2. Terryruiz
    Terryruiz , May 27, 2018 :
    no comparison at all 5T knocks it out the park !!!! and look at the apps being used on 5T they drain more battery than ones used on 6
  3. Daan_Eekhofアニメ
    Jelly Bean May 27, 2018
    Terryruiz likes this.
  4. G_n_jan_kjfm
    Donut May 27, 2018
    G_n_jan_kjfm , May 27, 2018 :
    The phone just got released, there are still optimisation needed for the software so the battery life will get better. If you want better battery life go to advance settings and change recent apps management to deep clear. It should improve it a little.
    If you still need more get root and xposed then install greenify, amplify and maybe zz power nap(not sure if it works with android 8.1). There are guides on how to set them up properly.
  5. Marcori
    Donut May 27, 2018
    Marcori , May 27, 2018 :
    guys ur missing the point.. let's wait for further updates and the snap 645 won't disappoint u anymore
  6. Terryruiz
    845 but prob feels like 645 lol
  7. Marcori
    Donut May 27, 2018
    sorry bro all these numbers makes me mad[e]1f602[/e]
  8. Terryruiz
    it's ok I had to put that sorry ....
  9. Darwin94
    Gingerbread May 27, 2018
    Darwin94 , May 27, 2018 :
    You guys are complaining about stuff too early. The device just came out. It would have some updates that potentially would increase battery duration overtime and fix other things.
    Probably that 5T screenshot wasn't when it got released without any updates and fixes.
  10. sleveille44
    Donut May 27, 2018
    sleveille44 , May 27, 2018 :
    I noticed excessive gaming and possibly viruses from torrent sites were draining my OP5 battery and my OP6 is handling gaming nicely but, I'm staying away from torrenting on mobile.
  11. Terryruiz
    I understand all that have oneplus 6 are hoping that some magic software update will improve a 3300 battery that OnePlus has been using since the OnePlus 2 ..ok OnePlus 3T had 3400 but rest were 3300
    it's OnePlus fault should of known to use bigger battery in first place
  12. Shuller
  13. mr_faust
    Donut May 27, 2018
  14. Terryruiz
    but if they put a 3800 or higher battery in 6t I hope no one moans who bought the 6 .....the 6t has to have a bigger battery or it will not sell !!!!
  15. Marcori
    Donut May 27, 2018
    Unfortunately they didn't use a larger battery but improvements can arrive via software updates, but yes in they future they could use bigger battery if they can keep the phone not to heavy or thick
  16. Terryruiz
  17. Terryruiz
    well I will not be given my money to Oneplus any more until they at least update there battery .....rest they can get away with but I do not want to go back 5+ years allways worrying about battery time like old mobiles
  18. Darwin94
    @Terryruiz You're a heavy battery complainer from what I can see over your recent posts. If you're such a heavy user and you need a bigger and better battery duration you should search a different brand or different phone that can certainly met your necessities or just stick with your OP5. For me OP6 is giving me some good 7 or 8 hrs SOT with some normal to heavy usage, good for me. Pretty sure that this can be improved with some software updates in the future tho.
    Marcori likes this.
  19. Terryruiz
  20. Terryruiz
    your in short supply getting that SOT ....Most on here moaning who have OnePlus 6
