255
  1. isatis eppe
    Cupcake May 27, 2018
    isatis eppe , May 27, 2018 :
    anyone has problems with the front facing camera ?
    I have the 6 and when I'm trying to take a picture with the front camera and if a move a bit it gets blurry, but if I do this on VIDEO mode it's not blurry at all and it's even fluid
  2. khalid2509
    Froyo May 28, 2018
  3. pablofg1978
    Head Moderator Head Moderator May 28, 2018
    pablofg1978 , May 28, 2018 :
    Merged
  4. Terryruiz
    Ice Cream Sandwich May 28, 2018
  5. keithluken
    Cupcake May 28, 2018
    keithluken , May 28, 2018 :
    Funny with low brightness I am projecting about 4-4.5 screen time, how do you see 7 hours?
  6. Terryruiz
    Terryruiz , May 28, 2018 :
    OnePlus 5 heavy use between 9- 10 Hours ie watching sky Q ...Amazon prime ..YouTube ...BBC iPlayer etc
  7. Terryruiz
  8. tqqq
    Gingerbread May 28, 2018
    tqqq , May 28, 2018 :
    Battery suck is the worst part.
  9. highspeedsandy
    Eclair May 28, 2018
    highspeedsandy , May 28, 2018 :
    I had around 50% of battery before sleeping. Woke up to see my phone was dead. This Android System is sucking the most battery. Please help. I'm getting around 3hrs of SoT. :/
  10. Dark_Matrix_Guru
  11. Terryruiz
  12. Dark_Matrix_Guru
    Dark_Matrix_Guru , May 28, 2018 :
    Stop going to sleep.... Problem solved
    Tom_Com_01 likes this.
  13. Dark_Matrix_Guru
    And on cellular data the entire time. You have to give the phone time to calibrate the battery just like the previous oneplus device
  14. Terryruiz
  15. highspeedsandy
    Eclair May 28, 2018
    Thanks. Very much need this advice.
    Dark_Matrix_Guru likes this.
  16. Dark_Matrix_Guru
    Does no one remember having to allow the phone to calibrate the battery for a few days? Also if you did not charge to 100% before the first use you will have battery drain issues. This information is on EVERY devices instructions.
    For non rooted phones the battery calibration is done via cycle lives of the battery:
    1. Let your phone die
    2. Charge it while powered down to 100%
    3. Turn it on charge to 100%
    4. Let it in charge for 20min even when 100%
    5. Turn phone off charge to 100%
    6. Go to recovery and clear cache
    7. Charge the phone in power off to 100%
    8. Turn it in repeat steps from 3. To 7.
    Tobi_W96 and highspeedsandy like this.
  17. Dark_Matrix_Guru
    1) Clear the cache of your phone
    {settings - storage & memory - storage - tap on
    cache}
    2) Clear the Google play services' cache
    {settings - apps - Google play services - storage -
    tap on clear cache}
    *IMPORTANT*
    DO NOT PRESS THE BACK KEY NOW!
    3) Reboot your phone in recovery mode and wipe
    the cache
    4) Once it's booted, let it sit there for a couple of minutes
  18. geneing
    Eclair May 28, 2018
    geneing , May 28, 2018 :
    Day 2: battery life is excellent. Average usage, by late afternoon I'm at 75%. Cell signal is average in my neighborhood, but it doesn't seem to affect op6 as much as it did my old op1.
  19. Terryruiz
    geneing
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e] have you even looked at the screen or been on standby all the time .....show proper screen so see we can 1527471272004.jpg
    what's running like this ...
  20. geneing
    Eclair May 28, 2018
    Terryruiz
    1.5 hours SOT, mid-low brightness. The weather is too nice to be looking at the screen.
    I'm surprised that GPS also doesn't drain the battery too fast. yesterday I had GPS on for 2 hours while hiking. Only lost 10% of the charge, maybe.
    Playing PUBG on the other hand drains the battery like crazy.
