196
  1. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer May 23, 2018
    NeVeR_SeTTLe , May 23, 2018 :
    Wipe your cache from Recovery and let the battery settle for a few days.
    #81
  2. D1527047970648
    Donut May 23, 2018
    D1527047970648 , May 23, 2018 :
    what to do with heating issues? bought a flagship killer to realize it's too hot to handle
    #82
  3. NeVeR_SeTTLe
    How hot is hot? Did you measure the temp with CPU-Z?
    #83
  4. venkatoneplusone
    Eclair May 23, 2018
    #84
    asaputrosnk likes this.
  5. D1527047970648
    Donut May 23, 2018
    it's heating like am iron rod not able to use it.using ear phones to call people. please let me know how to intimate refunds
    #85
  6. NeVeR_SeTTLe
    May you measure the temperature with CPU-Z and post screen shots of your temperatures please.
    #86
  7. Amitabh4u
    Froyo May 23, 2018
    Amitabh4u , May 23, 2018 :
    zong1388
    Currently Im using op2 and I'm planning to buy a new phone. since I use the phone heavily like lot many apps, I'm still skeptical to go for the same brand. so looking for more suggestions on whether to go for op6 or a lower version op5t will help me.​
    hi!
    You should go with oneplus 6 because battery anyways gonna improve by rolling out of software updates.
    what you should consider is quality and performance at a price not more than 2k incdifference between the actual prices of op5t and op6.
    spend 2k extra and you get 3 additional things compared to 5t:
    1. bigger and better screen (difference you will observe is not more than 5% than op5t)
    2. better camera as the primary camera has OIS compared to previous model (op5t) (difference you will observe is not more than 5% compared to 5t). However, OIS helps alot in night photography compared to 5t which is not a night photography phone as compared to other phones out in the market with same camera specs.
    3. both SIM slots support 4G and VoLTE
    I used to have 5t and my friemd still has it so points mentioned are after observing the differences.
    Good luck and don't forget 2000 cashback offer for sbi card and sbi debit cards users.
    #87
    AnishBmMindfreak likes this.
  8. D1527047970648
    Donut May 23, 2018
    sorry but my first hand experience is not worth it.i bought an 8gb+128 gb model.this thing becomes hot like iron rod.features are so so. from no where it's a flagship killer.if I am able to claim revert would like to go for S9
    #88
    cereal_kllr and Terryruiz like this.
  9. zong1388
    Cupcake May 23, 2018
    zong1388 , May 23, 2018 :
    thanks for your expertise... I'll be going for OnePlus 6. but still more hungry to hear reviews. like mentioned earlier op team had already promised to provide rollouts for previous versions for battery issues. yet no signs of improvement
    #89
  10. Amitabh4u
    Froyo May 23, 2018
    but my phone is not getting that hot .. however, be patient as I too fel that after charging it heats up a bit but new update should improve it.
    #90
  11. soumgroy
    Froyo May 23, 2018
    soumgroy , May 23, 2018 :
    it's way too early man. but till now the battery drainage rate is much lower than my previously owned op3t.
    #91
    ghostofcain likes this.
  12. Amitabh4u
    Froyo May 23, 2018
    to be practical, sooftware updates never helps you get battery life by just few tweaks and we think now we will get 10 hours of experience compared to earlier 8 hours of usage.
    roll outs do not bring any big changes as these changes cannot be observed.
    However, what you should see is how much is the battery life you are getting when your phone is untouched (ex: when you sleep and no other activity is ongoing except your background android processes) as your phone is not in use and if your battery drains more than 6-8 % than I think you should be concerned. If it does not drain then your battery is just fine and you need to learn some battery optimizations tips and tricks and care your battery by not using phone when it is on-charging.
    my battery was 36% when I left my phone with my bluetoth headset connected and when I got up after 6 hours, my battery was still at 36% now this got me confused and I am still not able to figure it out how is that posible on oneplus (trust me i never experienced this with oneplus 3 and 5t).
    I hope this helps you!
    #92
  13. G_Prasheel_Tawar
    #93
    Rosschist likes this.
  14. zong1388
    thats true software updates doesn't provide long life for the battery... just enhances the performance.
    which phone are you using now ?
    #94
  15. Amitabh4u
    Froyo May 23, 2018
    I am currently usin oneplus 6
    #95
    zong1388 likes this.
  16. Drsj
    Gingerbread May 23, 2018
    Drsj , May 23, 2018 :
    not getting hot, even relatives bought it, no problem battery giving max of 6 hrs sot, best to turn off automatic screen brightness
    #96
  17. Drsj
    do a hard reset and don't back up install as new phone it makes a difference
    #97
  18. scorpionmania
    scorpionmania , May 23, 2018 :
    Getting issues with the video call quality in whatsapp. Both the recieving side and sending side are getting very blurry, choppy and jagged video quality. Tried on both Wifi (150 MBPS broadband on both sides ) and cellular networks ( LTE data speed on both sides )
    Is there a solution OR is this an image processing software bug ?
    I used samsung Note5 untill yesterday with no issues of this kind. I am certain it is an issue on oneplus side.
    Any one else facing this issue are well ?
    #98
  19. Catalin_Buzescu
    Jelly Bean May 23, 2018
    Catalin_Buzescu , May 23, 2018 :
    Do you have any idea what you are writing here? At least if you don't know, don't bother to spread fake info.
    There have been a lot of updates oneplus released containing battery optimizations, and while this is something more subjective, a lot of users reported bigger battery life and SOT.
    Also, improvements could be added through updates for improved performance, camera, and many more
    #99
    Santoshtheone and NeVeR_SeTTLe like this.
  20. zong1388
    did you just read what the actual post is before imposing your statement ?
    did you make an attempt to google what's the difference between a firmware/software updates. please do read about it once !
