256
  1. S1531221984634
    Cupcake Aug 26, 2018
  2. Parth1+6
    Eclair Aug 26, 2018
    Parth1+6 , Aug 26, 2018 :
    Battery draining fast in 5.1.11 oxygen OS version compared to previous version.
    Battery drained fast even in phone in stand by (non use) while sleeping.
    Previous version was batter as far as good battery concern.
    Give update and improve battery as soon as possible.
    Thanks One plus.
  3. amirhussaini93
    Ice Cream Sandwich Aug 26, 2018
    amirhussaini93 , Aug 26, 2018 :
    Wait, you changed led color, then you use what to charge your phone?
    If charging rapidly, it will appear blue to say fast charging active.
    L1535300307029 likes this.
  4. nagarjuna003
    Gingerbread Aug 26, 2018
    nagarjuna003 , Aug 26, 2018 :
    Iam facing same issue.i observed that compare to previous version ,this version battery drain faster.
  5. Parth1+6
    Eclair Aug 26, 2018
    You mean to say due to Dash charging it appears as a blue?
  6. Parth1+6
    Eclair Aug 26, 2018
    yaah true
  7. amirhussaini93
    M1531291958904
    Yes man. If you use dash charge, you change what ever color, will appear blue because fast charging activated.
    But, if you use charger that dont have fast charging OnePlus, it will appear what color you set. Such like powerbank or another phone charger.
    So, it appear blue to tell user that fast charging is activated. [e]1f601[/e]
    Parth1+6 likes this.
  8. Parth1+6
    Eclair Aug 26, 2018
    ohh now i get it...i m using only dash charger and not any other charger or powerbank
    Thanks brother [e]1f44d[/e]
  9. amirhussaini93
    No problem man. I just help you clarify about charging led color. [e]1f60a[/e]
  10. Achyuta_kaushik_27
    Donut Aug 26, 2018
    Achyuta_kaushik_27 , Aug 26, 2018 :
    Since the last Oxygen OS update I feel the phone heats up pretty quick and bad when playing a graphic intensive game like Pubg (on the highest settings possible).This wasn't happening before. Anyone else noticed this or what?
  11. Parth1+6
    Eclair Aug 26, 2018
    yaah thanks...
    But have you face the problem of fast battery draining issue in 5.1.11 version as compared to previous version?
    Praveen_N_Patil likes this.
  12. amirhussaini93
    Idk man. I'm using HydrogenOS Open Beta 2. [e]1f602[/e]
    I saw few people say battery worst on OxygenOS 5.1.11 but few people also claim battery good on OxygenOS 5.1.11. xD
    Different people, different usage, different result.
    C1535130495928 and Parth1+6 like this.
  13. Musibatt_
    Musibatt_ , Aug 26, 2018 :
    yup! Even i noticed it. my op6 heat'sup even when i opend my snapchat i don't no what's the problem but OnePlus should fixed it with next update (Android p).
    anyone have an idea when it will touch to our op6?
    EmzeO likes this.
  14. Achyuta_kaushik_27
    Donut Aug 26, 2018
    Depends on the company itself,whenever they decide to get it done,my take is it'll be rolling out in the coming or next month.
  15. Musibatt_
    As it was a part of beta version. OnePlus should releases it after one week but they are not still ready....
    Achyuta_kaushik_27 likes this.
  16. koullis83
    koullis83 , Aug 26, 2018 :
    Pubg does that to my phone too and wifi signal is worst since last update. Before it was fine, good signal no heating issues.
    Achyuta_kaushik_27 and Musibatt_ like this.
  17. Parth1+6
    Eclair Aug 26, 2018
    Ohhk but my daily usage is more or less same. but after update i experienced that battery drains quicky
    N1534778312082 likes this.
  18. T1530550668236
    Donut Aug 26, 2018
    T1530550668236 , Aug 26, 2018 :
    Am experiencing the same thing , also the battery is getting heated during charging. Are u facing heating during charging too?
  19. Ranjith0512
    Donut Aug 26, 2018
    Ranjith0512 , Aug 26, 2018 :
    yes .. absolutely
  20. CheeZeArtZ
    Froyo Aug 26, 2018
    CheeZeArtZ , Aug 26, 2018 :
    Hey Guys, reporting back!
    After applying some of the settings you guys suggested, including draining the battery to 0, this is my result after the following usage pattern:
    Listening to my JBLs over bluetooth for around 2 hrs
    Playing Pokemon Go for a solid hour
    Browsing Instagram and Reddit throughout the day
    Pretty heavily using Snapchat (3 Min SoT = 1% Battery i mean WTF Snapchat?!)
    I will proceed to uninstall Snapchat and Pokemon for the following charge and have a look at the impact, if you guys want I can update you on that front.
    Have a nice Sunday everyone!
    Artemus likes this.
