256
  1. Chrishko
    Cupcake Aug 26, 2018
  2. Deactivated User
    Aug 26, 2018
  3. C1535130495928
    Donut Aug 26, 2018
    C1535130495928 , Aug 26, 2018 :
    same problem here bro
  4. xnutzii
    Lollipop Aug 26, 2018
    xnutzii , Aug 26, 2018 :
    You know, don't use the phone while charging and it won't get hot. Or don't use anything "intense", meaning don't use anything that needs cpu power, it won't harm the phone, tho the phone will get hot, because that's still how physics work.
    phemt likes this.
  5. Ranjith0512
    Donut Aug 26, 2018
    Ranjith0512 , Aug 26, 2018 :
    why was physics not working before this update?[e]1f602[/e][e]1f602[/e][e]1f602[/e]
    T1530550668236 likes this.
  6. T1530550668236
    Donut Aug 26, 2018
    T1530550668236 , Aug 26, 2018 :
    ohk, whatever u just said isn't a solution to the problem, there was no heating issue before and there is one now after their OTA updates , so clearly it is a fault of the OS. They need to fix this and roll out stable OTAs.
  7. xnutzii
    I said it already, it's your damn imagination, this is so cringe.
    I don't have to waste any time, since you don't understand anything about phones or physics in general.
  8. Natraj03
    Eclair Aug 26, 2018
    Natraj03 , Aug 26, 2018 :
    yes same here
  9. Sharry7
    Ice Cream Sandwich Aug 26, 2018
    Sharry7 , Aug 26, 2018 :
    Yeah it heats up on highest. But i you set fps on high rather than ultra , you will face very less heat
    Achyuta_kaushik_27 likes this.
  10. EmzeO
    Honeycomb Aug 26, 2018
    EmzeO , Aug 26, 2018 :
    In the last weekly update they told sth about updates about pie in the next weekly update so stay fresh
  11. AveshShaikh007
    AveshShaikh007 , Aug 26, 2018 :
    I m also facing the same problem...also my battery is draining quickly ...while gaming and using camera..
    Natraj03 likes this.
  12. Shield10
    Shield10 , Aug 26, 2018 :
    I am also facing the same issue ,my mobile network is not stable and If I use camera for more than 10 minutes device get pretty warm and camera starts to slow down.
    AveshShaikh007 likes this.
  13. AveshShaikh007
    while using camera m also facing the same problem
    Shield98 likes this.
  14. gubro
    KitKat Aug 26, 2018
    gubro , Aug 26, 2018 :
    We do not have enough pubg threads, this one is really needed.
  15. Natraj03
    Eclair Aug 26, 2018
  16. G_Rohith_Ramesh_rPvx
    Eclair Aug 26, 2018
    G_Rohith_Ramesh_rPvx , Aug 26, 2018 :
    i have getting 3-4hour battery life on continues use....dash charge is super .....but it is very fast draining battery.....any tips to get more battery life plz say....
  17. Natraj03
    Eclair Aug 26, 2018
    no solutiom, its actually battery problem itself...
    G_Rohith_Ramesh_rPvx likes this.
  18. G_Rohith_Ramesh_rPvx
    Eclair Aug 26, 2018
    hmm....is this similar problem to op6 users.....if face lock take any battery consuming high...
  19. nagarjuna003
    Gingerbread Aug 26, 2018
  20. Natraj03
    Eclair Aug 26, 2018
    no am not using face lock, still am not getting good battery life...in photos also am getting blury images in both front and rear cam
