196
  1. abhishekbhavsar
    Cupcake Oct 12, 2018
    Tanguy De Moor likes this.
  2. Heena Varia
    Ice Cream Sandwich Oct 12, 2018
  3. abhishekbhavsar
    abhishekbhavsar , Oct 12, 2018 :
    yes this issue start after pie
    in 8.1 phone never get warm or heatup
    even if you Play heavy games
    need too be fixed
  4. U1529226460320
  5. Cervantes
    Lollipop Moderator Oct 12, 2018
    Cervantes , Oct 12, 2018 :
    Please, read the first threads posts
    Use the search before opening redundant threads
    Thread merged
  6. eSenKaa
    Froyo Oct 12, 2018
    eSenKaa , Oct 12, 2018 :
    Got lots of trouble with my battery since Oreo. My Phone is in air plane mode thé night and I lost like 30% of battery. Insane. Could some one help me ?
  7. M1538709989150
    M1538709989150 , Oct 12, 2018 :
    Hello there
    I have just bought Oneplus 6 a week ago. I am facing the following issues
    The custom notifications for most applications come to "default notification" after afew hours.
    There is no update interval settings in Weather app
    The phone is getting heated up frequently and gets restarted when I have more than 3 apps in background
  8. L1539198549281
    L1539198549281 , Oct 12, 2018 :
    me to bro. same issue. I could not find a solution. Waiting for help. The phone will drain the battery to more than 30% in standby mode. there was no problem. The problem started after the update of android 9. I reset it three times. android i've returned to oreo 8.1. still no solution. I'm going crazy.
  9. eSenKaa
    Froyo Oct 12, 2018
    Yeah I dont understand, by the way fast charge is working well and my Phone can stay without charging like for 7 hours. I hope there will be a fast fix.
  10. abhishekbhavsar
    dude did you merge my question in a battery drain threads??
    if yes please remove that
    the problem m facing is different
    its about heating not about battery drain
  11. frankie_hr
    Donut Oct 12, 2018
    frankie_hr , Oct 12, 2018 :
    Hi everyone,
    After a couple of weeks of battery drain struggles, I finally took the last available solution and performed a factory reset of the phone. I am thrilled to announce that the factory reset definitely solved the battery drain issue. My battery is currently on 23% (15 hrs left) with last full charge performed 2 full days ago!
    I have to say I wasn't happy about having to do it, as it took me about half a day to bring the contents of my phone back to a state as it was before the reset, but at least the final outcome is positive, so for all of you looking for a quick way to solve the Android Pie battery drain issue, here's where the answer might be.
    Having that said, there definitely IS something weird happening with the battery after the upgrade from Android 8.1 to 9, as there are many people reporting it in the forums (including myself). This is something the OP developers should definitely look into as the factory reset is not really the most suitable solution and it is unrealistic to expect all users to have to do a full factory reset in order to solve the battery issue.
    Cheers!
  12. Deactivated User
    Oct 12, 2018
  13. Tanguy De Moor
    Gingerbread Oct 12, 2018
    Tanguy De Moor , Oct 12, 2018 :
    Thanks for merging the thread it could be helpfull for some people. But in my case I allready read the topics in the community and found that the topic you set my message in didn't fit anymore because of the NEW update android 9 instead of android 8 software issues. That's why I started a new topic not because i didn't read it, it's because it didn't help, just so you know maybe ask first about the circumstances before merging.
    btw had to contact custome support hopeing for a solution.
    Kind regards,
    Tanguy
  14. RudyC
    Donut Oct 12, 2018
    RudyC , Oct 12, 2018 :
    this is getting really annoying.
    this is the situation with:
    - battery save mode ON
    - all apps background activities disabled in settings
    - disable all syncs in the "account" menu
    normal usage, just WhatsApp and chrome as you can see. And this is the situationt after less than 2 hours SOT.
    The other day:
    seriously......my old iPhone 6 had better battery life with push notifications and blablabla all enabled. Big thumb down.
    Is there a way to get Google play service logs and check what is triggering it? Can't find relevent info
  15. Deactivated User
    Oct 12, 2018
  16. mojoyoyo77
    Lollipop Senior Moderator Oct 12, 2018
    mojoyoyo77 , Oct 12, 2018 :
    These problems are common, if it is a problem with a specific version of Android P use the official sticky thread of that update, and most importantly: report on the site indicated in the first post so that it can be studied / corrected
  17. YasSkiller
    Gingerbread Oct 13, 2018
  18. E1539295603302
    Cupcake Oct 13, 2018
    E1539295603302 , Oct 13, 2018 :
    How can i check my ram space and how to clean caches ? Please help me out because I'm afraid that it's a lot cache have contained into that.
  19. YasSkiller
    YasSkiller , Oct 13, 2018 :
    U can check ur rame by getting to debelopper options in ly system ( u can get it by clickung 7 topes ur phone seri ) Then can cjeck ur ram statue
  20. E1539295603302
    It's battery draining too fast since I updated system of my phone. Please let me how can i stop draining.
    YasSkiller likes this.
