200
  1. anoop180
    Cupcake Oct 13, 2018
    anoop180 , Oct 13, 2018 :
    the battery is draining even if I'm not using the phone....it happened for 3 days..so i turned on the battery saver option
    Echovelox likes this.
  2. Kytharsis
    Marshmallow Oct 13, 2018
    Kytharsis , Oct 13, 2018 :
    That's normal. No need to turn on Battery Saver unless you absolutely have to.
    V1539266935304 likes this.
  3. anoop180
    thanks man...that was helpful [e]1f603[/e]
    Kytharsis likes this.
  4. S1532947893110
    Eclair Oct 13, 2018
  5. S1532947893110
    Eclair Oct 13, 2018
  6. AfroKryptonian
    Donut Oct 13, 2018
    AfroKryptonian , Oct 13, 2018 :
    I've realized a weird battery drain after the Android P update. I've realized a 20% drop in battery over a 5hr period of no usage of the phone.
    I hope the next update will resolve this issue. Background drain without even using the phone.
  7. afta.abdulhady@g
    Best Answer
  8. Z1510087056721
  9. afta.abdulhady@g
    AfroKryptonian likes this.
  10. Cervantes
    Lollipop Moderator Oct 13, 2018
    Cervantes , Oct 13, 2018 :
    You check this thread: tips to take care of the battery, read the first post
    Please read first, second and third post of the update
    https://forums.oneplus.com/threads/oxygenos-9-0-for-the-oneplus-6.909533/
    Thread merged
  11. AfroKryptonian
    Donut Oct 13, 2018
    Keep in mind the phone is on Battery Saver mode as you can see in the image.
    An update focusing on the battery should come out soon
  12. mr.david
    Donut Oct 13, 2018
    mr.david , Oct 13, 2018 :
    Got the same problem. After PIE update i have to charge the phone twice per day to be able to use it before Pie it worked for almost 2½ days.
    Tried a full system restore (with the option to delete everything) left the phone on (without any custom apps, settings changed or anything installed and noticed the same Battery drain, so the problem come with the update, not settings or apps.
    pedroalex13 likes this.
  13. K1536419293812
  14. Deactivated User
    Oct 13, 2018
  15. Deactivated User
    Oct 13, 2018
  16. Kytharsis
    Okay, who marked this post "Best Answer"?
    yash297 likes this.
  17. pedroalex13
    Cupcake Oct 14, 2018
    pedroalex13 , Oct 14, 2018 :
    is This normal for the One plus laucher APP to use This mutch battery? I already clear cache
  18. Deactivated User
    Oct 14, 2018
  19. pedroalex13
  20. pedroalex13
