177
  1. methodii Cupcake Nov 7, 2018
    methodii, Nov 7, 2018 :
    It really depends on your setup.
    I can guarantee you this results are not possible on 4G for examlpe.
    The only way you can get 10hrs of streaming is on WiFi and Battery Saver settings enabled.
    What is your os version/build?
    Share screenshot or else it is just fake lies.
  2. Anorak211994 Eclair Nov 7, 2018
    Anorak211994, Nov 7, 2018 :
    I updated my OnePlus 6 to OxygenOS 9.0.2. After the update I have noticed faster battery drain that before. I found similar complaints on Reddit. Is anyone experiencing this issue on OnePlus 6? Will it be fixed in next 9.0.4 stable update? Thank you!
  3. F_Louis_Riquier_NKBL Donut Nov 7, 2018
    Anorak211994 likes this.
  4. Deactivated User Nov 7, 2018
    deangilvin likes this.
  5. Kytharsis Lollipop Nov 7, 2018
    Kytharsis, Nov 7, 2018 :
    No one can help if you don't post your stats.
    deangilvin and Deactivated User like this.
  6. _makala_srikanth Cupcake Nov 7, 2018
  7. Deactivated User Nov 7, 2018
  8. Anorak211994 Eclair Nov 7, 2018
    I'm using the same apps as before in the same capacity. Still I'm noticing faster battery drain.
    cas8180 likes this.
  9. Deactivated User Nov 7, 2018
  10. Deactivated User Nov 7, 2018
    deangilvin and Kytharsis like this.
  11. Anorak211994 Eclair Nov 7, 2018
    I've been using pie since I got the phone. Which is 25 days ago. I got the 9.0.2 update on 5th Nov. The amount of apps before 9.0.2 and after 9.0.2 update are same. When the phone was on 9.0 the battery drain was noticably lower than what it is now.
  12. Kytharsis Lollipop Nov 7, 2018
    Post your stats so we can see what's draining your battery.
  13. Deactivated User Nov 7, 2018
    Kytharsis likes this.
  14. Anorak211994 Eclair Nov 7, 2018
  15. Anorak211994 Eclair Nov 7, 2018
  16. Deactivated User Nov 7, 2018
    Kytharsis and deangilvin like this.
  17. Anorak211994 Eclair Nov 7, 2018
    I was using the same apps before. I've told it 3 times already. Thanks for nothing!
  18. Deactivated User Nov 7, 2018
  19. Maverick2.0 Ice Cream Sandwich Nov 7, 2018
    Maverick2.0, Nov 7, 2018 :
    9.0.5 is for the 6T.
  20. P1538151560972 Cupcake Nov 7, 2018
