223
  1. M0h1t Sharma
    Froyo Nov 10, 2018
  2. Vandit_S.S
    Gingerbread Nov 10, 2018
  3. Vandit_S.S
  4. positve_electron
    Donut Nov 10, 2018
  5. M0h1t Sharma
    Froyo Nov 10, 2018
    M0h1t Sharma , Nov 10, 2018 :
    yupp.. what to do now
    other 3300mah battery also gives grtt battery bb then op6
  6. Vandit_S.S
  7. Artemus.
    Nougat Nov 10, 2018
  8. Vandit_S.S
  9. M0h1t Sharma
    Froyo Nov 10, 2018
  10. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Nov 10, 2018
    Its.Leandroo , Nov 10, 2018 :
    PUBG may not be optimized for Android 9. Battery drain is normal for graphic intensive games, but you can contact the developer of the app for further assistance.
  11. Vandit_S.S
    Vandit_S.S , Nov 10, 2018 :
    yes
  12. Vandit_S.S
    M0h1t Sharma likes this.
  13. M0h1t Sharma
    Froyo Nov 10, 2018
    ok I'll try
  14. M0h1t Sharma
    Froyo Nov 10, 2018
    i think this will be only fix by oneplus coz many other custom roms give great bb in adroid pie
  15. malidan
    Nougat Nov 10, 2018
    malidan , Nov 10, 2018 :
    Wow that's pretty shocking.:confused:
    I take it you are using the officials from play store and not some version from elsewhere?
    If so use the usual OP fix and clear the usual corrupted cache.;)
  16. Its.Leandroo
    It's not. This is something the developer of the app can look at, and maybe improve. OnePlus can't fix 3rd party apps.
    Deactivated User likes this.
  17. Vandit_S.S
    yes
  18. Deactivated User
    Nov 10, 2018
    Artemus. likes this.
  19. Deactivated User
    Nov 10, 2018
    positve_electron likes this.
  20. vamsi279
    Donut Nov 10, 2018
