223
  1. Cervantes
    Lollipop Moderator Nov 15, 2018
    Cervantes , Nov 15, 2018 :
    Please read the first, second, third post
    Thread merged
    Artemus. likes this.
  2. RudyC
    Donut Nov 15, 2018
    RudyC , Nov 15, 2018 :
    just live with it, no reason to struggle finding a solution.
    tried everything here:
    - no sync
    - 99% of my apps are not allowed to use battery and data in background
    - battery save mode on
    - limit data usage on
    - Google play services can't use data in background and can't edit system settings (this was the thing I hoped would solve the issue, since I found many threads with this suggestion)
    - cleared cache and data several times
    - tried to uninstall play service updates then to install the latest beta version
    - I don't have any notifications on, just WhatsApp
    still...well you can see the image below (and no, it's not Facebook or other apps, these are old screenshots. I am avoiding any usage now, just to test it, using only via browser and NO other apps, is the same)
  3. Deactivated User
    Nov 15, 2018
  4. Sasikumar15
    Cupcake Nov 15, 2018
    Sasikumar15 , Nov 15, 2018 :
    I also faced this issue. Try below steps... it solved my issue...
    Try this....
    Go to Settings ---- > Security & lock screen ---- >
    Under security status go to Google play protect ---- >
    Turn off Scan device for security threats...
    Reply if solved your issue also...
  5. Mikegyro
    Eclair Nov 15, 2018
    Mikegyro , Nov 15, 2018 :
    One thing that was different for me in Usage that day with high Google services usage versus my usual was that I had used the what's up app that day. I've noticed every one of these screenshots except for maybe 1 has it there. I can't say I've noticed this issue before, and I don't use what's app but maybe once a month.
  6. prakash_diwakar
    Honeycomb Nov 15, 2018
    prakash_diwakar , Nov 15, 2018 :
    clear complete storage of google play service app and force stop service and renoot. it will redownload all files. Check whether it solve ur issue.
  7. dejan.jandric
    Eclair Nov 15, 2018
    dejan.jandric , Nov 15, 2018 :
    I am also facing a draining battery problem, but It aint with Play Services. I used ti have 7-8 SOT, nowadays I only have up to 4-5 SOT.... Hope next software update will fix it...
  8. G_raghav_talwar_qQLL
    Donut Nov 15, 2018
    G_raghav_talwar_qQLL , Nov 15, 2018 :
    IS oxygen 9.0.2 has any kind of battery issues in the software ? will oneplus next update fix these issue? or there aren't any issue with the software at all?
  9. Deactivated User
    Nov 15, 2018
  10. G_raghav_talwar_qQLL
    Donut Nov 15, 2018
    is there any proper way which could fetch more battery life like keeping it between 10 and 90 % all the time? or any tips and tricks ? if i go into settings and then apps and close notifications for unwanted apps will it help to improve battery? because i think app will be sending notification in this case but the phone will not be showing us ?
  11. nolandc
    Eclair Nov 15, 2018
    nolandc , Nov 15, 2018 :
    Yeah no issues at all... that's why there's 30+ people on this thread complaining about piss poor battery life after the last update?
  12. Artemus.
    Nougat Nov 15, 2018
    Artemus. , Nov 15, 2018 :
    This is what happens when people don't troubleshoot their issues and expect OP to magically optimize every single app in the Play Store.
    Deactivated User likes this.
  13. nolandc
    Eclair Nov 15, 2018
    Then there's people blaming apps even when some people are saying they have not installed any...
    Vladka Evelyn likes this.
  14. Artemus.
    Nougat Nov 15, 2018
    Doesn't mean they're optimized for Pie. This happens every major version update. Devs focus on the majority version to save time.
  15. Deactivated User
    Nov 15, 2018
  16. tuntun kumar
    Cupcake Nov 16, 2018
    tuntun kumar , Nov 16, 2018 :
    here everyone is received new op6 (within one week) but is there anyone who is facing heating and battery issue after update 9.0.2.
    I have been using op6 for 3 months and was not facing any issues but after update 9.0.2, I'm facing heating issue at the upper part of the op6 near camera and also battery is getting discharged within 6 hrs.
    I've posted the same in 2-3 threads.
    below is the thermal and battery status of my op6 .Please help me if anyone is having any Idea how to fix this issue.
  17. Artemus.
    Nougat Nov 16, 2018
    Artemus. , Nov 16, 2018 :
    Your battery looks fine from what I see. Maybe play less PUBG?
  18. tuntun kumar
    but earlier I used to play pubg even more and didn't face any heating issue nor batty was getting drained quickly.
    why I'm facing this issue after update 9.0.2
  19. Artemus.
    Nougat Nov 16, 2018
    Simple: placebo effect. ;)
  20. tuntun kumar
