213
  1. 786143.ys
    Cupcake Nov 17, 2018
  2. Leo Biglia
    Leo Biglia , Nov 17, 2018 :
    Guys i have a really bad battery issue: when i unplug the phone at 100%, after a few minutes (3-4) in standby (only data on) it goes down to 99% and so on the standby in general is very bad. In five hours of standby without doing nothing I lose between 8-10%. Anyway the SOT Is normal, between 5 - 7 hours with usual use. Tell me what do you think about these problems
  3. rohany24
    Froyo Nov 17, 2018
    rohany24 , Nov 17, 2018 :
    really you don't even know whatsapp is open in the background and you are saying only camera app and how can we believe you that no other apps is opened in the background as you don't even know whats app is open looking at notifcation bar.lmao and most probably you got 10s of apps running behind
  4. 411
    411 , Nov 17, 2018 :
    yes I know there are lot of apps are running in background,which is the normal thing and as I say while using camera app only mobile is heating , and also Oneplus is most powerful smart phone and also it have 8 gb of RAM also it is heating ..why? on normal usage? 48degree
  5. 411
    in every smart phone background apps are running bro and it is not require to tell.....
  6. rohany24
    Froyo Nov 17, 2018
    there is difference between background apps some apps are background free and some don't whats app is not in that free category.You can use greenify and check it.And it is best app for root and non root i suggest to download it and see it do its work
  7. B1529919050946
    Eclair Nov 17, 2018
    B1529919050946 , Nov 17, 2018 :
    Dear OnePlus team
    Battery is draining so much
    Battery performance has become Worst
    Please Fix this issue
  8. Deactivated User
    Nov 17, 2018
  9. Deactivated User
    Nov 17, 2018
  10. wizard19999
    Gingerbread Nov 17, 2018
    Kathulapalli likes this.
  11. Let1107
    Eclair Nov 17, 2018
    wizard19999 and Kathulapalli like this.
  12. Z1542438504845
  13. Deactivated User
    Nov 17, 2018
  14. Kathulapalli
    Donut Nov 17, 2018
    Kathulapalli , Nov 17, 2018 :
    what's ur screen on time?
  15. AmitKumarDas
    Froyo Nov 17, 2018
    Akshaykkxkz likes this.
  16. AmitKumarDas
    Froyo Nov 17, 2018
  17. Chakith kumar
    Donut Nov 17, 2018
    Chakith kumar , Nov 17, 2018 :
    Ah. True. Usually, I get around 7+ hours.
  18. Kathulapalli
    Donut Nov 17, 2018
    Ahh... Is it really good to charge upto 100%?
  19. Deactivated User
    Nov 17, 2018
  20. Kathulapalli
    Donut Nov 17, 2018
    Wowww..Jus woww
