177
  1. Adi Das Donut Jan 12, 2019
    Adi Das, Jan 12, 2019 :
    thanks for guiding man!
    Kytharsis likes this.
  2. Cervantes Lollipop Moderator Jan 12, 2019
    Cervantes, Jan 12, 2019 :
    Please read the first post
    Thread merged
  3. parimal1712 Cupcake Jan 13, 2019
    parimal1712, Jan 13, 2019 :
    the time between this two screenshots is almost 5 hours.....as 3:54AM to 8:52AM...... battery level down by almost 20% in no use condition...... screen is off,data connection is off......it is sleepy time for my one plus like me (night time)......so let me give some information guys.....is it a quite normal thing which i was facing or every one facing this situation???..........and what about solution
  4. schreder Gingerbread Jan 13, 2019
    Trampdyna likes this.
  5. L1547049801594 Donut Jan 13, 2019
    L1547049801594, Jan 13, 2019 :
    Can you completely wipe the OP Launcher from your device?The reason - a massive battery drain caused by it
    Before my last charge, the launcher had consumed 27% of the battery. Usually it's around 10-15%
    No widgets on the home screen, the only gesture that I'm
    using is double tap to wake/lock.
    A few days ago I contacted the OP support. The guy there
    told me to delete the launcher and that the phone cah work
    as good as ever even without it
    I asked if the launcher would be completely wiped or just replaced with an old version and he assured me that it'll be
    gone for good.
    Can anyone give an advise on what may cause the launcher to eat the battery like this, and if it's possible for the phone to work without the launcher?
  6. Kytharsis Lollipop Jan 13, 2019
    Kytharsis, Jan 13, 2019 :
    Install a third-party launcher and change that to default launcher.
  7. L1547049801594 Donut Jan 13, 2019
    Thanks, but I'm trying to get an answer to the question asked.
    Is it possible to completely get rid of the OP launcher and also, why the heavy drain at all (phone being used for voice calls only recently)
  8. Kytharsis Lollipop Jan 13, 2019
    You can disable it but not completely remove it without root. To answer your question about not using a launcher at all, no. A launcher is required.
  9. L1547049801594 Donut Jan 14, 2019
    L1547049801594, Jan 14, 2019 :
    Thank you! Kinda makes you wonder how helpful the OP support really is since according to them, the launcher can be completely wiped, with your phone "working as good as ever" ..
  10. drl431 Jelly Bean Jan 16, 2019
    drl431, Jan 16, 2019 :
    If there is a difference, it is not much. I'm still getting 7+ hours sot and 2+ days between charges.
    Battery duration is about your apps and how you use them.
    An update cant change that (other than delaying notifications).
  11. drl431 Jelly Bean Jan 16, 2019
    Generally;
    social media apps sync often, try to reduce that.
    games with intensive graphics, reduce graphic settings.
    2 sims use more power.
    weak cell service uses more power.
  12. L1545923777955 Cupcake Jan 18, 2019
    L1545923777955, Jan 18, 2019 :
    Hi buddy..
    even i am facing a similar issue. i bought my one plus 6t on 24 dec 18 and i am having similar rate of drainage... which is 1 percent in 5 minutes.
    without using any video calling or you tube...
    its eating up the battery.
    i have restricted the background data of almost all apps.
    have hardly any app installed... but this is not what i bought my op6t for.
    Please help and guide.
    Also clarify does one plus replace the battery as the performance is not as desired as compared to other op6t devices.
    Thanking you in anticipation.
    Regards.
    Really worried.
  13. Kytharsis Lollipop Jan 18, 2019
    Kytharsis, Jan 18, 2019 :
    I think you're looking for this thread. :)
  14. OnceHeaven Honeycomb Jan 18, 2019
    OnceHeaven, Jan 18, 2019 :
    1% = 5mins
    100% = 8hrs+
    whats the problem here? work on your expectation and learn to post in the correct section
  15. ChaosAdmRL Cupcake Jan 19, 2019
    ChaosAdmRL, Jan 19, 2019 :
    Can someone tell me the SOT I should expect? Because I was told that Fortnite is a huge reason my phone just drained in 3.5 hrs even though it was just 1 hour of fortnite.
    Anyway I spent an entiee day without fortnite using apps that only a casual consumer would use : Very little time on Netflix, Facebook, Chrome. The performance is still bullshit. 3 hrs and 45 mins and the phone already lost 70% of the battery. I used to get an SOT of more than 6 hrs easy even when I played Fortnite before this update.
  16. L1545923777955 Cupcake Jan 19, 2019
    L1545923777955, Jan 19, 2019 :
    buddy thats the problem...
    just 8 hours.... shouldn't this device give you a min of 36... when no heavy apps are being run. alll background restrictions are on and synching is also switched off.
  17. L1545923777955 Cupcake Jan 19, 2019
    the sot is hardly 4 hours....
    its a concern...
    ChaosAdmRL likes this.
  18. ChaosAdmRL Cupcake Jan 19, 2019
    Exactly. Even without the heavy apps, its capping at 5 hrs maximum. That's when I didnt use ANY battery extensive app just to check if Fortnite is to be blamed for my observations.
  19. Kytharsis Lollipop Jan 19, 2019
    Kytharsis, Jan 19, 2019 :
    Netflix and Facebook could drain it too. Games just do it faster. ;)
  20. ChaosAdmRL Cupcake Jan 19, 2019
    Are we supposed to keep the phone in the pockets to reach that SOT then mate? These are day to day used apps that weren't an issue earlier. It's like a standard "That's what's doing it excuse" I find after this update. The same apps easily gave screen usage upto 6-7 hrs easy earlier.
