177
  1. Kytharsis Lollipop Jan 19, 2019
    Kytharsis, Jan 19, 2019 :
    Some screenshots will definitely help, you know.
  2. OnceHeaven Honeycomb Jan 19, 2019
    OnceHeaven, Jan 19, 2019 :
    actually, if you have used enough Android devices and long enough, you'll know its a common complain. if you could, save all your app apks, factory reset, dont sign into your Google account. you'll see the amazing battery you so desire.
    the above tests shows that OP isnt the issue
  3. San2Sreshta Gingerbread Jan 19, 2019
    San2Sreshta, Jan 19, 2019 :
    forget about those, Can you post yours battery usage also please.
    I really want to see yours as whenever I search for any suggestions or something related to battery, you just come in the middle and ask for battery status. can you do it please.
  4. H1529153259909 Donut Jan 19, 2019
  5. anupritaisno1 KitKat Jan 19, 2019
    anupritaisno1, Jan 19, 2019 :
    Your phone when left on a charger even when it's at 100% starts optimisation
    If you do not let this optimisation complete by letting your phone be in a charger for a few hours even after it's at 100% you will face battery drain
    After a system update this optimisation has to be redone from scratch
    If the optimisation doesn't complete the system does on the fly optimisation
    On the fly optimisation is fire and forget code so the same thing has to be optimised again and again because the result cannot be saved
    On the fly optimisation is performed by JIT which runs in the context of android system
    When you show the battery chart with the show full device usage option selected from the 3-dot menu on the top right we see how much battery android system is using
    If it's using too much then you didn't allow the phone to complete optimisation
    The solution: preferably charge your phone overnight while it is turned on
    Do not wipe caches as this will make it worse
  6. EmmanDomUy Cupcake Jan 19, 2019
    EmmanDomUy, Jan 19, 2019 :
    Mine is 0% used since last full charge And I'm happy that my OnePlus does not have battery issue.
  7. anupritaisno1 KitKat Jan 19, 2019
    People often want things fast without realising that everything takes it's own time to happen
    Battery drain is common after a system update but users just want the fix. They don't want to know why it happens.
    Kytharsis and drl431 like this.
  8. F1547903775756 Cupcake Jan 19, 2019
    F1547903775756, Jan 19, 2019 :
    Totally, after the recent update I noticed that the battery was draining really fast. I was in Sub-Zero temperatures right after the update so I thought it was probably because of the cold weather but once I came back home (Chennai) where the weather always fairly average, the problem still persists. Kindly do something about this OnePlus.
  9. San2Sreshta Gingerbread Jan 19, 2019
    alright, but why did you reply to me instead of others who are expecting such kind of explanation??
    I am happy to see my battery giving 7 to 8 hrs of SOT .
  10. H1529153259909 Donut Jan 19, 2019
    H1529153259909, Jan 19, 2019 :
  11. C1546142980002 Cupcake Jan 19, 2019
    C1546142980002, Jan 19, 2019 :
    For you here having battery drain issues, have you tried wiping the cache partition from the bootloader?
  12. anupritaisno1 KitKat Jan 19, 2019
    Stop
    Do NOT wipe cache
    This will make battery drain worse
    Kytharsis likes this.
  13. anupritaisno1 KitKat Jan 19, 2019
  14. anupritaisno1 KitKat Jan 19, 2019
    You asked why battery statistics are needed
    I gave you a proper explanation
    I told you what the guy was looking for in the screenshot
  15. pgrey Honeycomb Jan 19, 2019
    pgrey, Jan 19, 2019 :
    I'd try the above-poster's suggestion too, about using Data-Saver.
    I pretty much leave this on, with a couple of apps in the exception list (allowed data when data-saver is on), most of the time, and see very little performance hit, but it does help a LOT, in terms of background battery drain.
    When it's enabled, it prevents any app, except those given exclusion permissions, from using background data.
    Obviously, you don't want to apply this to things like "phone", and "messages", and some of the system apps must not be prevented from background processing, as well.
    This DOES prevent things like apps that are "tracking your every move" from running constantly and using a TON of battery, unless you explicitly allow them.
    I use maybe 3-5%, overnight, with this enabled, for example.
  16. Kytharsis Lollipop Jan 20, 2019
    drl431 likes this.
  17. R1531937076963 Cupcake Jan 20, 2019
    R1531937076963, Jan 20, 2019 :
    using Bluetooth connection for 15 mins for listening the music drops battery percentage by 5 %
    One plus is providing any fix or battery issue any time sooner...or it cannot be resolved...??
  18. pgrey Honeycomb Jan 20, 2019
    pgrey, Jan 20, 2019 :
    This drain in the graphs above is (mostly) due to the Social apps.
    My daughter uses Instagram, mostly, and it's a HUGE draw, even when set to NOT run in the background (because foreground updates pull SO much data). WhatsApp has long been a huge data-user, too, and also (obviously) a huge battery sink.
    Like @Kytharsis says, "if you're happy with those 3 hours...", well that's a choice.
    If you want to get more than that, you'll have to disable background data for those apps, and limit their foreground use as well (disable all the auto-download of videos, etc).
    If you're using a TON of data, plus codecs and more to translate it, that's a LOT of battery drain, both data-driven and CPU, there's just no way around it.
    As for the Bluetooth drain, can you please post your battery graphs, as well? The 5% for 15 minutes might be perfectly normal, depending on what else is running, simultaneously...
  19. NeatNit Eclair Jan 22, 2019
    NeatNit, Jan 22, 2019 :
    (trying to post here since it won't let me make a new thread and it's half-related to this topic)
    I got this phone fairly recently (about a month ago), and I'm absolutely loving it.
    Two things that I want to know about though:
    1. Taking care of the battery - I try to never charge over 80% and never go under 30%, with varying degrees of success. I want this phone to last me a long time. Is there a way to request that they add an option to stop charging at 80% automatically? I don't want to overcharge it by forgetting. I hear some root-based apps can do this, but I'd prefer to stay unrooted.
    2. Why is the built-in call recording feature disabled in almost all countries? In my country it's 100% legal to record all calls you have with other people, even without their knowledge, as long as you are a member of the conversation. I had to use an app called jOnePlus Tools to enable this feature. Does anyone know if this app is in any way dangerous?
    Regarding root - is it possible to get root while still receiving OTA updates, without risk of data wipes? (even if I'd have to re-root every update)
  20. drl431 Jelly Bean Jan 22, 2019
    drl431, Jan 22, 2019 :
    You can not create a thread for 15 days after creating an account unless you begin with the Stating Point area.
    I fully cycle the battery of a new phone a few times in the beginning. There are apps for what you want to do, but I wouldn't bother. Besides the system cache is reorganized if the phone is powered up when the battery reaches 100%.
    You can use the search function to find the many threads about phone recording.
    About rooting, if you use online banking apps, they could be disabled...
