182
  1. supra-bay Froyo Mar 31, 2019
  2. Kytharsis Lollipop Mar 31, 2019
  3. U1537697037219 Donut Mar 31, 2019
    U1537697037219, Mar 31, 2019 :
    there seems to be a connectivity issue too. phone tends to keep losing speed. i have to have activate aiplane mode again and again to gain speed.
  4. sanjai10 Froyo Apr 1, 2019
  5. sid12021 Donut Apr 2, 2019
    sid12021, Apr 2, 2019 :
    I am from India. I ha e OnePlus 6. And I don't know that it's because of summer here or what but my phone is Heating without any reason. Even using Instagram for 15 minutes resulted in heating my phone. and phone is Heating up so much while charging. Solve this problem as soon as possible. not a good experience with the phone.
  6. sid12021 Donut Apr 2, 2019
    same problem with me. I didn't factory reset it yet. but My phone is Heating in just 15 minutes of using of any small application. and it's heating as hell while charging.
  7. aakaashgoyal Cupcake Apr 8, 2019
    aakaashgoyal, Apr 8, 2019 :
    Same issue. Battery draining like crazy. Can't seem to find a viable solution for this.
  8. G_Aslam_Shaikh_IqHl Cupcake Apr 10, 2019
  9. G_Gautham_Vinod_yiAC Cupcake Apr 10, 2019
  10. M1554997227075 Cupcake Apr 11, 2019
    M1554997227075, Apr 11, 2019 :
    We have the same problem but currently the maximum Google Play Services drains is about 26%.
    As soon as I see the app active and feel that the phone gets warm, I restart the phone. Usually the problem is solved and Google Play Services is not active then.
    So far that is the only available option for me because it seems like with the 6t you cannot request a forced stop for Google Play Services nor can you activate battery optimization for it :(
  11. George1314 Cupcake Apr 11, 2019
    George1314, Apr 11, 2019 :
    Good evening guys
    I have the same problem, I have screensot 5hours Screen on and now only 2 or 3 hours.
    NoMoreFun likes this.
  12. Enchantress Donut Apr 11, 2019
  13. Kytharsis Lollipop Apr 11, 2019
    Kytharsis, Apr 11, 2019 :
    That's because Google Play Services isn't actually running, it's just a framework/API. The reason it appears to be high usage is because other apps are pinging it so often. What I would suggest is turning off auto-sync.
  14. bjorg18 Gingerbread Apr 13, 2019
    bjorg18, Apr 13, 2019 :
    Hi guys, hope you all are having a good day. I have a query I thought I would ask. It is bugging me from a long time.
    Whenever my phone is in the pocket for a long time, it shuts off automatically. Most of the times my phone is either on the desk or in the bag but when it's in the pocket, it shuts off. This is seriously annoying. Can anybody tell me what's happening?
  15. khaled.20 Cupcake Apr 13, 2019
    khaled.20, Apr 13, 2019 :
    hey just got my op6 I'm on 5.1.8 and I'm attempting to update it to 9.0.4 but I'm a bit skeptical about the battery life decrease as in a lot of users complaint .
    I want some advice as in to update or just stay on my 5.1.8 oos
  16. alexansBROS Froyo Apr 13, 2019
    alexansBROS, Apr 13, 2019 :
    Try, if you have problems then downgrade.
  17. khaled.20 Cupcake Apr 13, 2019
    from ur experience is it worth it or not?
  18. alexansBROS Froyo Apr 13, 2019
    from my experience 1 month ago my phone started to drain a huge amount of battery and now it's not usable..
  19. khaled.20 Cupcake Apr 13, 2019
    thank this means I'm staying on 5.1.8
  20. khaled.20 Cupcake Apr 14, 2019
    khaled.20, Apr 14, 2019 :
    hello is ur battery performance still good ? or has it decreased after the update
