182
  1. malidan Marshmallow Apr 14, 2019
    malidan, Apr 14, 2019 :
    Your battery saver turned on at 35%.:confused:
  2. G_Josvin_SS7 Froyo Apr 15, 2019
  3. malidan Marshmallow Apr 15, 2019
  4. G_Josvin_SS7 Froyo Apr 15, 2019
  5. malidan Marshmallow Apr 15, 2019
    malidan, Apr 15, 2019 :
    Stats should not include battery savers, they distort the result.:rolleyes:
  6. G_Josvin_SS7 Froyo Apr 15, 2019
    G_Josvin_SS7, Apr 15, 2019 :
    [e]1f602[/e] okay then 7 hrs 42 mintues battery saver not enabled
    * I got many results saved in my screenshots that's why suddenly replying
    * Oxygen os 9.0.4
  7. malidan Marshmallow Apr 15, 2019
    So battery saver on at 15% only.give you an extra 18 min.:( Your SOT time is starting to tumble.;)
  8. G_Josvin_SS7 Froyo Apr 15, 2019
    malidan
    So battery saver on at 15% only.give you an extra 18 min. Your SOT time is starting to tumble.​
    I am not a hard user [e]270c[/e]️
    the both results are of variant occasion the 8 hrs sot with battery saver is while I am touring ( less usage )
    The second 7 hrs 42 mintues screen on time while I played some games with out battery saver I played Coc 20-25 minutes Mini miltia 12 minutes ( one custom match)
  9. D1555457057252 Cupcake Apr 17, 2019
  10. khaled.20 Cupcake Apr 17, 2019
    khaled.20, Apr 17, 2019 :
    my battery life is getting better by the second full charging cycle after I drained the battery to 13% I charged it to 100% now after 3 hours of sot I'm still at 70% with using Facebook and messenger and YouTube
    these are my screenshots
    I want to know if this is very good or just nrml cuz I heard s9+ users can't get 4h sot
  11. A1550387522048 Gingerbread Apr 18, 2019
    A1550387522048, Apr 18, 2019 :
    After 9.0.4 I faced with fast draining problem especially On Screen and I tried to change the Google Play Services version. At the end I reached a good standby longevity but still have problem on screen use exclusively when I surf on Google chrom. The chrom page is white I try to turn a dark page but no option for android today. Can you share some other good ideas to solve fast draining on screen???
  12. G_Gautham_Vinod_yiAC Cupcake Apr 20, 2019
    G_Gautham_Vinod_yiAC, Apr 20, 2019 :
    I recently noticed that Google play services are using soo much battery on my device ..it has reached a point that it consumes the most amount of battery . is there a fix to this ?
    alexansBROS likes this.
  13. alexansBROS Froyo Apr 20, 2019
  14. G_Gautham_Vinod_yiAC Cupcake Apr 20, 2019
  15. Kytharsis Lollipop Apr 20, 2019
  16. alexansBROS Froyo Apr 20, 2019
    alexansBROS, Apr 20, 2019 :
    45 minutes of screen? this is not fine
  17. Kytharsis Lollipop Apr 20, 2019
    Kytharsis, Apr 20, 2019 :
    You're at 75%. You can easily attain more than an hour depending on how much you use your phone before it dies.
  18. alexansBROS Froyo Apr 20, 2019
  19. Kytharsis Lollipop Apr 20, 2019
    Use your phone as normal till it hits 10% then post another screenshot. This will be the best statistic to know what's causing it.
  20. alexansBROS Froyo Apr 20, 2019
    play services I think
