200
  1. anupritaisno1
    KitKat Mar 10, 2019
    anupritaisno1 , Mar 10, 2019 :
    For everything really
  2. sreelekhaaitha
    Donut Mar 11, 2019
    sreelekhaaitha , Mar 11, 2019 :
    Hey, charged my phone overnight as u said... haven't used it at all properly... i don't know why google play services is consuming so much!
    dsmonteiro likes this.
  3. kiratplusone
    Student Ambassador India Mar 11, 2019
  4. Deactivated User
    Mar 11, 2019
    Kytharsis likes this.
  5. kctharun2002
    Cupcake Mar 12, 2019
    B1552379465164 likes this.
  6. theshinybeast
    Marshmallow Mar 12, 2019
  7. Cervantes
    Lollipop Moderator Mar 12, 2019
    Cervantes , Mar 12, 2019 :
    You can explain the problem
    You use the phone when it is charging
    You check the connectors are clean
  8. kctharun2002
    kctharun2002 , Mar 12, 2019 :
    no I don't use it while charging
  9. Cervantes
    You can read the first and fourth post
    You can upload a screenshot of the battery and use of battery, by the google browser
  10. kctharun2002
    please help me
  11. Cervantes
    I do not see something serious in the battery, a lot of consumption: youtube and instagram
    You can take the phone to a service center to have it reviewed
  12. dsmonteiro
    Community Consultant Mar 12, 2019
    dsmonteiro , Mar 12, 2019 :
    He keeps giving the same answer to everyone and ignoring the fact that it often doesn't do anything. Try clearing cache from recovery and then reply back:
    1. First of all turn off your phone. and get into the recovery menu.
    2. Now, to get into recovery menu. Press Volume Down + Power Button. And keep on holding the buttons till you get into recovery menu.
    3. Select Language.
    4. Use volume buttons to navigate to Clear Cache/Data. and use the power button to select this option.
    5. Now you will see two separate options, One will clear cache of your OnePlus device other one will delete all the data present in your phone.
    6. Select Wipe Cache Option.
    7. Reboot your phone.
  13. sreelekhaaitha
    Donut Mar 12, 2019
    sreelekhaaitha , Mar 12, 2019 :
    I followed this procedure yesterday afternoon. And charged my phone to 100% again at night!
    Today it's working!
    Feel much better now with the battery performance!
  14. anupritaisno1
    KitKat Mar 12, 2019
    anupritaisno1 , Mar 12, 2019 :
    Good to know how you like to suggest placebos
    Ever considered the actual reboot might be fixing it?
  15. dsmonteiro
    I have tried rebooting, it didn't work whereas clearing cache did.
    You should consider that it worked (like on previous occasions). Unlike the advice you keep throwing around. I already pointed out this on your thread and you decided to ignore it: I tried your method against this one. One worked, the other didn't. But you're too full of yourself to hear anything different.
    You thread says clearing cache should worsen his issue. It helped.
  16. anupritaisno1
    KitKat Mar 12, 2019
    And where is your proof?
  17. dsmonteiro
    Where's yours?
    Because the empiral evidence disproves your "let it charge overnight" advice while proving that clearing cache, if anything, at least does more than letting it charge.
  18. juustomies
    Eclair Mar 13, 2019
    juustomies , Mar 13, 2019 :
    ite started again. My battery drains extremely fast. like in 2 hours with normal usage. (normally like 4-7 hours with my using habits) so some fix to that please. this is like 7months ole phone.
    adi1001, George1314 and sidhutaran56 like this.
  19. Billmatth
    Cupcake Mar 13, 2019
    Billmatth , Mar 13, 2019 :
    can you help me guys
    my battrey life didnt survive long enough like it used to.
  20. Kytharsis
    Marshmallow Mar 13, 2019
