193
  1. RudYaroslav Cupcake Jun 3, 2019
    RudYaroslav, Jun 3, 2019 :
    My one plus 6 get's too hot while serfing in chrome
    i think for snapdragon 845 it' complete unacceptable. Guys please help, it started after last system update.
    Even after disposal of all resources it hard to use it due to its temperature
    Hope you'll give me an answer
    Thank in avance for helping
  2. RudYaroslav Cupcake Jun 3, 2019
  3. nabbed Honeycomb Jun 3, 2019
    nabbed, Jun 3, 2019 :
    It sounds like you installed an app that mines cryptocurrency.
    Sharry7 likes this.
  4. RudYaroslav Cupcake Jun 4, 2019
    RudYaroslav, Jun 4, 2019 :
    It seems like One Plus got a serious problem with optimization. If users while searching the internet run into such a problem
  5. Tobikage Nougat Jun 4, 2019
    Tobikage, Jun 4, 2019 :
    No...you need to find out which apps are hogging your CPU / GPU.
    Wouldn't count this out either....
  6. RudYaroslav Cupcake Jun 4, 2019
  7. Tobikage Nougat Jun 4, 2019
    Check what processes are running , Check what's using up the battery ?
  8. dharminder397 Cupcake Jun 4, 2019
  9. schreder Gingerbread Jun 5, 2019
  10. RudYaroslav Cupcake Jun 6, 2019
    RudYaroslav, Jun 6, 2019 :
    Nothing extraordinary. Youtube and chrome that's it. But phone temperature makes the use of it not comfy
  11. CmonStoke Cupcake Jun 6, 2019
    CmonStoke, Jun 6, 2019 :
    @RudYaroslav I have also noticed the same when in chrome since last update 9.0.5 also I get a warning that chrome is draining the battery.
  12. Govindarajan_Srinivasan Froyo Jun 8, 2019
    Govindarajan_Srinivasan, Jun 8, 2019 :
    self was also having heating issues after couple of updates in OnePlus 6.
    please advise as yesterday received latest update for OnePlus 6.
    khaled.20 likes this.
  13. RudYaroslav Cupcake Jun 8, 2019
    RudYaroslav, Jun 8, 2019 :
    i've updated to the latest version and problem wasn't fixed. It still very hot while searching the internet. Please fix that. In here snApdragon 845 it can't be that hot under normal you while web searching. In my former samsung s3 with snap 440 there weren't any problems. It pitty to realize that company that tell everyone about speed, can't handle overheating
  14. RudYaroslav Cupcake Jun 8, 2019
  15. Z1533557334970 Cupcake Jun 9, 2019
    Z1533557334970, Jun 9, 2019 :
    I have issues with battery drain on OnePlus 6 after the last update(India) .
    Currently on Oxygen OS Version 9.0.6
    kernel version: 4.9.106-perf+# 1 Tue May 28 13:33:09 CST2019
    Build Number
    OnePlus A6000_22_190528
  16. Rognar Eclair Jun 9, 2019
    Rognar, Jun 9, 2019 :
    Now you will be advised to clear the cache or make a hard reset. Perhaps this will help, but the point is in the work of the firmware on the Indian device. While the developers do not recognize this, nothing will change.
  17. Cervantes Lollipop Moderator Jun 9, 2019
    Cervantes, Jun 9, 2019 :
    Hi
    The battery thread is a thread of questions and/or commentary
    Please, read the first and second post
    Thread merged
    Kytharsis likes this.
  18. G_Samarth_Srivastava_yjM Froyo Jun 10, 2019
    G_Samarth_Srivastava_yjM, Jun 10, 2019 :
    my phone is getting heated whenver i use normal apps such as Instagram WhatsApp Messenger why is that so i am not even playing hogh resolution games then why is this happening its getting more heated then mi phones now
  19. khaled.20 Cupcake Jun 10, 2019
  20. vipugpta Cupcake Jun 10, 2019
    vipugpta, Jun 10, 2019 :
    me too, have noticed this. Now a days the battery drains 10-15 % overnight compared to 3-4 %earlier. Any suggestions...?
