195
  1. ThePSLongchamp
    Cupcake Aug 22, 2019
    ThePSLongchamp , Aug 22, 2019 :
    Calibrate ?
    Dude, I'm working as an IT tech, I know how to calibrate the battery of my phone and I know how to diagnose a problem on my device and this problem wasn't there before.
    I mean, I have my location disable, I close every apps I use when I'm done using it, I reboot my phone several times and for more than a year that I've got this phone, I never had any problem with. Except since yesterday, just after installing the last OxygenOS update, what a coincidence.
  2. Kytharsis
    Marshmallow Aug 22, 2019
    Kytharsis , Aug 22, 2019 :
    This literally happens every single update yet people still complain about it. Drain to 10%, charge overnight past 100% (the longer the better), do this again two to three times. Trust me, this works.
  3. Q1566568498138
    Cupcake Aug 23, 2019
    Q1566568498138 , Aug 23, 2019 :
    Wrong, this does not happen every update. I have never needed to calibrate my battery before, nor have other people who have this exact phone, it generally works just fine. After this update, I too am having battery issues, calibration does jack shit.
    I unplugged my phone at 6:30 am, used it to play spotify via bluetooth for about 20 minutes, then haven't used it at all since. It's down to 78%. From 100%. Prior to the update this would be down to maybe 90-95%.
  4. Antonio Trolio
    Donut Aug 24, 2019
    Antonio Trolio , Aug 24, 2019 :
    i have the oxygen os 9.0.8 and my battery goes to fast down/low and the phone is heating. camera have problems to. what to i do now?
  5. Kytharsis
    Marshmallow Aug 24, 2019
    Kytharsis , Aug 24, 2019 :
    You can start by posting a screenshot of your battery graph as well as giving more details to what your problems are. We're not mind readers. ;)
  6. Antonio Trolio
    Donut Aug 24, 2019
  7. L1566703855582
    Cupcake Aug 25, 2019
    L1566703855582 , Aug 25, 2019 :
    kindly tel me how to wipe cached data... I couldn't see any recovery option
  8. Antonio Trolio
    Donut Aug 25, 2019
    Antonio Trolio , Aug 25, 2019 :
    I have already done, but I still have battery, heat and camera problems
  9. Kytharsis
    Marshmallow Aug 25, 2019
    Kytharsis , Aug 25, 2019 :
    When someone tells you to clear cache in recovery, don't. There is no cache partition and is a placebo effect.
  10. Antonio Trolio
    Donut Aug 25, 2019
    so i installed now the beta of google play service 19.0.56 (direct from google play store) and I hope it has a positive impact.I'll test it 24 hours (or more) and get back to you to tell more
  11. Rohit_Paul
    Rohit_Paul , Aug 25, 2019 :
    fist go to about phone from setting,then on buildnumber click seven times to activate developer option, then activate advance rebbot option from developer option.
  12. Antonio Trolio
    Donut Aug 25, 2019
    Antonio Trolio
    so i installed now the beta of google play service 19.0.56 (direct from google play store) and I hope it has a positive impact.I'll test it 24 hours (or more) and get back to you to tell more​
    So here is my preliminary result. It has gotten better but under about 40% the battery feels faster empty and the smartphone starts to get hot. Link for google play service beta https://play.google.com/apps/testing/com.google.android.gms
    FelipeLeo likes this.
  13. Antonio Trolio
    Donut Aug 25, 2019
    Update: is heating again :( we need new oxygen os update !!!
  14. Kytharsis
  15. Antonio Trolio
    Donut Aug 25, 2019
    Kytharsis
    Download CPU-Z from the Play Store and screenshot the thermals.​
    i downlaod now the beta 24 and first a make a back up with one plus switch. if the beta have the same battery and heating problem, i will roll back to 9.0.2
  16. Kytharsis
    Wait, wait, wait. You were on 9.0.2 this entire time?
  17. Antonio Trolio
    Donut Aug 25, 2019
    i mean 9.0.8 [e]1f602[/e]
  18. Antonio Trolio
    Donut Aug 26, 2019
    Antonio Trolio , Aug 26, 2019 :
    Guys, install the Beta 24! she runs much better and my one plus 6 is running well again. I have no battery, camera and heating problems more. embarrassing that a beta is more stable than stock version. And you have in the beta digital wellbeing which is very cool and useful. Is there actually the possibility to switch later on Android 10 Sable version, without losing data? Because I think that was like that at the time when I had the beta and then later changed to stable version android 9.
    For more info about Beta 24 follow this link:
    https://forums.oneplus.com/threads/...us-6-and-open-beta-16-for-oneplus-6t.1086783/
    ps:
    Dear One Plus Team, before you release a stable version update, please test it in detail. I have no desire that my one plus 6 breaks because of your faulty software. otherwise you owe me a one plus 7 pro [e]1f61c[/e]
  19. Applephx
    Eclair Aug 26, 2019
    Applephx , Aug 26, 2019 :
    OBSERVATIONS:
    When my battery gets lower than 20% it tends to get relatively warmer regardless of usage and much warmer if I am doing something processor/graphic intensive than if the battery was at a higher level.
    It also gets much warmer (the warmest) if it is below 20% (give or take) and charging.
    HOW I MANAGE:
    Everything seems normal when at a higher batter level (over 40%) So I rarely let it get below that.
    ADDITIONAL TIPS:
    Remove unused apps. Many apps run in the background without you knowing.
    Avoid social media apps and be weary of many game developers since most are big on collecting data that Google gives them access to. These apps will wake your phone from powersave mode when your screen is off as well as run in the background. Each one adds a little more drain.
  20. FelipeLeo
    Cupcake Aug 27, 2019
