196
  1. Kytharsis
    Marshmallow Sep 29, 2019
    Kytharsis , Sep 29, 2019 :
    Social media apps like Whatsapp will cause this to happen.
  2. G1539522674011
    Donut Sep 29, 2019
    G1539522674011 , Sep 29, 2019 :
    What is the solution? Shouldn't I use social media apps?
  3. G1539522674011
    Donut Sep 29, 2019
    Find the battery stats
  4. rahulparur
    Eclair Oct 1, 2019
    rahulparur , Oct 1, 2019 :
    This battery stats shows Google play Store and Myntra are the main culprits.
    Google play Store: Update all app manually and clear the cache of google play store. Turn off auto updates and notifications as well.
    Myntra: If you are not using the application regularly, i suggest you to uninstall the app.
  5. G1539522674011
    Donut Oct 1, 2019
    G1539522674011 , Oct 1, 2019 :
    Google Play Services: followed the same but no use.
    I will be using Myntra.
  6. rahulparur
    Eclair Oct 1, 2019
    If you have done those changes just now, then wait for next charge cycle to complete.
    Turn off all the location services as well and restart.
  7. G1539522674011
    Donut Oct 1, 2019
    I have done those last week only and posted the screenshot after next cycle . kindly suggest any other changes if required.
  8. rahulparur
    Eclair Oct 1, 2019
    It is one of the google services mate.
    Check Smartlock, voice search etc any of these are enabled.
  9. L1535879402668
    Gingerbread Oct 2, 2019
    L1535879402668 , Oct 2, 2019 :
    yes. phone one plus. ask them to reverse your phone version to the original. the battery is amazing and you can use whatever app you want (which proves it's not the fault of the app- it's the fault of the update.)
  10. B1530637698516
    Cupcake Oct 3, 2019
    B1530637698516 , Oct 3, 2019 :
    I am using my OnePlus 6 for an year!! Now the battery life is very bad... I have worst experience in battery. Because the screen on time for my device is hardly 3 hours.Which was very bad for OnePlus.Any others facing these kind of problem?. please let me know.And give me some idea...
    Adithya S likes this.
  11. G1532774513322
    Cupcake Oct 8, 2019
  12. G_Sara_CcfT
    Cupcake Oct 11, 2019
    G_Sara_CcfT , Oct 11, 2019 :
    déjà fais... j'ai même réinstauré les paramètres usines et ça semblait s'être améliorer mais les -30% de batterie en une nuit en mode avion sont de retour ...
  13. G_Sara_CcfT
    like 1 or 2 weeks ago
  14. G_Sara_CcfT
    j'ai donc laissé quelques nuit en charge avec le réseau mais ça n'a rien changé ...
  15. entax
    Froyo Oct 11, 2019
    entax , Oct 11, 2019 :
    Salut,
    J'ai exactement le même souci sur un oneplus 6, qui a commencé la semaine dernière. J'ai vidé les cachés, mis à jour, etc, mais en vain! Il tenait 1.5j facile, avec un usage YouTube, musique modéré. Depuis la semaine dernière, en fin d'après midi, il est déjà à moins de 10%, avec un usage très très limité, seulement quelques courts appels...
    Edit: je précise, à part des mises à jour, j'ai strictement rien installé de nouveau sur le tel...
  16. G1539522674011
    Donut Oct 15, 2019
    G1539522674011 , Oct 15, 2019 :
    I have checked all those.. still I'm facing the same.
    Find the attached screenshot.
    28% consumed by Google Play services.
    What should be done? Should I change my phone?
  17. Horsault
    Marshmallow Moderator Oct 15, 2019
    Horsault , Oct 15, 2019 :
    Ces dernières semaines, j'ai beaucoup de soucis avec Google Photo, qui pompe sans vergogne sur la batterie. Regarde tes graphes de batterie, et les applis gourmandes.
  18. Kytharsis
    Marshmallow Oct 15, 2019
    Kytharsis , Oct 15, 2019 :
    Google Play Services is a framework, an app you're using (most likely WhatsApp) keeps polling it.
  19. G1539522674011
    Donut Oct 15, 2019
    This issue I'm facing from last few days.. earlier it was not like that...
  20. rahulparur
    Eclair Oct 16, 2019
    rahulparur , Oct 16, 2019 :
    Can you clear the Storage (Both cache and data) of Google Play Services & Google play store. Can you share the version details as well of these two?
