198
  1. vasek2
    Eclair Nov 10, 2019
    vasek2 , Nov 10, 2019 :
    Problem with battery drain of whatsup. Any help? Op6, android 10, Whatsup version. 308.
  2. Kytharsis
    Marshmallow Nov 10, 2019
  3. vasek2
    Eclair Nov 10, 2019
    Because I needed to go. But had it charged more before and the some result with battery drain.
  4. Kytharsis
    Kytharsis , Nov 10, 2019 :
    When is the last time you fully drained then charged fully and/or what OS are you on?
  5. vasek2
    Eclair Nov 10, 2019
    I have android 10, this started when I upgraded to 10. With pie not had problem. Have fully charged several times meanwhile but normally I charge up to 80-90% during day.
  6. Kytharsis
    Beta or stable?
  7. vasek2
    Eclair Nov 10, 2019
    Shay+ likes this.
  8. Kurro_arratiko
    Cupcake Nov 11, 2019
    Kurro_arratiko , Nov 11, 2019 :
    I have solved the problem downgrading to whatsapp version 2.19.298 all right after installing this version.
  9. HarshitVrihadOnePlus
    HarshitVrihadOnePlus , Nov 11, 2019 :
    Same issue on my OP 6T. It probably started after the most recent update. Comparing the graphs, my problem appears to be worse.
  10. JustSaying
    Gingerbread Nov 11, 2019
    JustSaying , Nov 11, 2019 :
    Thnx for the feedbacks. Now im sure that im not crazy
  11. theantz
  12. v_2
    Eclair Nov 11, 2019
    v_2 , Nov 11, 2019 :
    Have you guys tried downgrading the version of Whatsapp to check if the issue persists?
  13. v_2
    Eclair Nov 11, 2019
    Have you tried downgrading the version of Whatsapp to check if the issue persists ?
  14. v_2
    Eclair Nov 11, 2019
  15. Yashvendra_Singh_Raghav
    Ice Cream Sandwich Nov 12, 2019
  16. guisbro
    Honeycomb Nov 12, 2019
  17. Kurro_arratiko
    Cupcake Nov 12, 2019
    Kurro_arratiko , Nov 12, 2019 :
    With this version works fine whatsapp version 2.19.298
  18. Rahul Bhutkar
  19. vasek2
    Eclair Nov 12, 2019
    vasek2 , Nov 12, 2019 :
    I did via versa, I installed .328 which is only on whatsup website not on gplay yet. It looks better the battery, but I got problems with whatsup. Cannot share pictures or it got stuck by trying to sharte the picture from whatsup. I must go to gallery or photos and choose it from there to share photos...So I thinkt that the .308 drains, the .325 it is not fully ajusted. Any better experience with lower WU version on Android 10 on One plus?
  20. v_2
    Eclair Nov 12, 2019
    v_2 , Nov 12, 2019 :
    Since I installed it last night, I dont have a complete sample; Though based off today's usage whatsapp is 1% with about 45% batter left at 17:00 (off the power supply since 08:00am); Which is much better than what it was yesterday; I had about 20% by this time yesterday.
    But that being said let me use it for a few more day; only then can I decisively say that its improved in 327?
