200
  1. Kytharsis
    Nougat Jan 16, 2020
    Kytharsis , Jan 16, 2020 :
    I would not trust it.
  2. Vyserk1987
    Cupcake Jan 16, 2020
    Vyserk1987 , Jan 16, 2020 :
    Updated my Oneplus 6 8Gb/256Go last week to Android 10 from Android 9 and i couldn't understand why i lose so much battery since the update.... Now i see i am not alone with this issue...
    @Developpers : Have you a release date for an emergency hotfix ? My phone only last for 5h with a 100% charge... I am thinking to downgrade back to Android 9 if this issue continue... I don't understand how you can release an update that broke the phone like that and still not fixed it completely since mid-december 2019....
  3. Kytharsis
    Nougat Jan 16, 2020
    It's called "Calibrate the battery".
  4. Vyserk1987
    Cupcake Jan 21, 2020
    Vyserk1987 , Jan 21, 2020 :
    Hi, i think i found the root cause of the problem.
    I did a battery calibration like in this thread ( https://forums.oneplus.com/threads/battery-calibration.496817/ ) and he helped a little when i am not using my phone (battery drain was normal before i did that).
    But today, i saw a notification when i opened an apply that was saying "Game mode enabled", i searched to disable the gaming mode (like in a normal Android) but the option disappeared (in utilities) ! Instead of, there is a new app called "Game Space" which enable automatically game mode for several of my app which was melting the battery !
    This new app was added by OnePlus during the install of Android 10 and is impossible to be removed. I removed all apps from it and it seems it solved a lots of batteries issues !
  5. Kytharsis
    Nougat Jan 22, 2020
    Kytharsis , Jan 22, 2020 :
    Calibrate the battery... did you not learn after the last update?
    DrJMun likes this.
  6. DrJMun
    KitKat Jan 24, 2020
  7. nravhalai@gmail.
    Cupcake Jan 27, 2020
  8. Kytharsis
    Nougat Jan 27, 2020
    Kytharsis , Jan 27, 2020 :
    When is the last time you formatted the phone? Pretty sure this means either something has gone completely rogue or your battery needs to be replaced.
    DrJMun likes this.
  9. DrJMun
    KitKat Jan 27, 2020
    DrJMun , Jan 27, 2020 :
    You should realize you are NOT communicating with OnePlus via this forum. You are asking users, just like you, for help. If you've already tried to reset (format) your phone then you should access OnePlus support for this issue.
    Mike_Jiang and Kytharsis like this.
  10. W1577631418513
    Cupcake Feb 4, 2020
    W1577631418513 , via OnePlus 6 , Feb 4, 2020 :
    Battery/ Heating issues started from yesterday i.e 03/02/2020. Battery draining fast 100% to 40% within 3-4 hours with the same usage of my phone. I am also experiencing some heat issues since last two days.
    OP6 bought in June01, 2018
    Mike_Jiang likes this.
  11. DrJMun
    KitKat Feb 4, 2020
    DrJMun , Feb 4, 2020 :
    Did you see the suggestions above, by @Kytharsis to reformat your phone?
    Kytharsis likes this.
  12. W1577631418513
    Cupcake Feb 4, 2020
  13. Leonhard Scheiber
    Froyo Feb 7, 2020
    Leonhard Scheiber , Feb 7, 2020 :
    I had the same issue. Before, when not really using my phone, the battery would last for up to a week without recharging. With 10.3.0 the phone died just about every other night. In one case the battery which was fully charged before would go down by 45% over night with no messages coming in.
    The advice to calibrate your battery seems questionable because after going back to 9.0.9 all my battery issues went away and now the phone once again lasts forever on one charge (note that I mostly use this phone to receive texts for 2-factor authentication).
    DrJMun likes this.
  14. DrJMun
    KitKat Feb 7, 2020
  15. Akash_Pathak
    Cupcake Feb 9, 2020
    Akash_Pathak , Feb 9, 2020 :
    this is the situation of my battery since a long time. i can't get screen on time of more than 3-4 hours. and even if I don't use my phone. the battery drains a lot. is a software issue? or do I've to get my battery replaced?
  16. DrJMun
    KitKat Feb 9, 2020
    DrJMun , Feb 9, 2020 :
    There are several threads concerning Whatsapp and Facebook draining battery after applying 10.3.0. There was also a bug report in Feedback. Did you look at those?
  17. Dinekappu
    Froyo Feb 19, 2020
    Dinekappu , via OnePlus 6 , Feb 19, 2020 :
    what is the average screen on time for OnePlus 6, I get 4hours for moderate usage, if I am playing pubg game it getting 2.5 - 3 hours only
  18. Kytharsis
    Nougat Feb 19, 2020
    Kytharsis , Feb 19, 2020 :
    Average is highly dependent on your phone activity.
    drl431, DrJMun and Dinekappu like this.
  19. I1582205778641
    Cupcake Feb 20, 2020
