256
  1. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jan 3, 2020
  2. geneing
    Eclair Jan 3, 2020
    geneing , Jan 3, 2020 :
    I have the same issue. I found that turning off Bluetooth restored battery discharge rate to the old one. It's a pain having to toggle Bluetooth when I put on headphones.
  3. Ed Jones
    Froyo Jan 4, 2020
    Ed Jones , Jan 4, 2020 :
    Doing what right? An almost 20% battery drain in an hour with using very few apps?
    Artemus likes this.
  4. DrJMun
    KitKat Jan 4, 2020
    DrJMun , Jan 4, 2020 :
    Hmmmm, it does look odd. On that very same screen, if you click on the 3 vertical dots you'll see a selection for "Show full device usage". Does that indicate who the culprit might be?
    Ed Jones likes this.
  5. srsnth
    Donut Jan 5, 2020
    G1541777717518 likes this.
  6. Gtamkoria
    Cupcake Jan 5, 2020
    Gtamkoria , Jan 5, 2020 :
    i am facing the sane issue
  7. ironass
    Lollipop Jan 5, 2020
    ironass , Jan 5, 2020 :
    Charge your phone up to 100%. Use the phone normally until it reaches around 15%. Post screenshots of...
    Settings > Battery... also a screenshot of, "VIEW DETAILED USAGE".
    From these 2 screens it should be self evident which apps or settings are draining your battery and by how much as well as what is preventing it going in to Deep Sleep.
    G1541777717518, Artemus and Caoimhín like this.
  8. S1578184588011
    Cupcake Jan 5, 2020
  9. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 5, 2020
    ironass and Artemus like this.
  10. D1578252934867
    Cupcake Jan 5, 2020
  11. anandshrotriya17
    Donut Jan 7, 2020
  12. vik_freak
    Cupcake Jan 7, 2020
  13. Parthkansara
    Gingerbread Jan 7, 2020
  14. Parthkansara
    DevaDcruz likes this.
  15. K1527067387636
    Donut Jan 7, 2020
    K1527067387636 , via OnePlus 6 , Jan 7, 2020 :
    Me too facing this issue. Full charge not even sustaining for 5-6 hrs of regular usage.
    I suggest to have 9.0.8 os from service to solve this. 1+ team please fix this issue asap.
  16. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jan 7, 2020
  17. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 7, 2020
    Caomhin , via OnePlus 6T , Jan 7, 2020 :
    Just in case there is an App hogging resources, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
  18. I1577347987339
    Cupcake Jan 7, 2020
    I1577347987339 , Jan 7, 2020 :
    This does the trick
    goto Settings>Bluetooth & device connections>printing(turn this shit off)...wallah your battery is back to normal
