208
  1. B_Wrath
    Nougat May 4, 2020
    Artemus. and F1588564376594 like this.
  2. the_o2
    User of the Year 2018 May 4, 2020
    the_o2 , May 4, 2020 :
    As I can see there is a notification of heat warning for some app, you should force stop it or uninstall it if possible...
    And how the images of front and back of the phone is relevant to your issue, how people get idea of your phone getting hot or freezing :confused::confused:
    Maybe the summer is not enough :p:p
  3. SOUFIAN2020
    Cupcake May 4, 2020
  4. SOUFIAN2020
    Cupcake May 4, 2020
    SOUFIAN2020 , via OnePlus 6 , May 4, 2020 :
    🥺🥺🥺🥺. I tried all apps and the phone is warming up
  5. the_o2
    And what is your Oxygen OS version?
  6. SOUFIAN2020
    Cupcake May 4, 2020
  7. the_o2
    Version mate?
    Go to settings
    About phone
    And post the screenshot
    F1588564376594 likes this.
  8. Artemus.
    Nougat May 4, 2020
    Artemus. , May 4, 2020 :
    Which version of 10? 10.3.2 or 10.3.3?
  9. SOUFIAN2020
    Cupcake May 4, 2020
    the_o2 likes this.
  10. SOUFIAN2020
    Cupcake May 4, 2020
  11. the_o2
    F1588564376594 and Artemus. like this.
  12. Artemus.
    Nougat May 4, 2020
    Okay, now we got that figured out. Now tell us... what're you doing with the phone that's making it warm up? What apps do you use?
  13. Cervantes
    Lollipop Moderator May 4, 2020
    Cervantes , May 4, 2020 :
    Hi
    Please, use the battery thread for questions and comments for charging and heating issues
    Please, change photos for screenshot
    For another user to give you a suggestion, you must upload a screenshot of:
    battery and other of:
    battery uses
    You can install cpu-z and upload a screenshot of thermal
    Use the search engine before opening a new thread
    Thread merged
  14. SOUFIAN2020
    Cupcake May 4, 2020
  15. SOUFIAN2020
    Cupcake May 4, 2020
  16. Cervantes
    that's not the screenshot I ask You to upload.
    The ones you should upload are these:
    battery uses
  17. Diptesh6384
    Cupcake May 6, 2020
    Diptesh6384 , via OnePlus 6 , May 6, 2020 :
    whenever i play pubg in high settings like graphics smooth and frame rate extreme my phone heated within 3,4 minutes and battery drain 100 % to 80% within 3,4 minutes tell me the solution
  18. Artemus.
    Nougat May 6, 2020
    Artemus. , May 6, 2020 :
    The solution: stop playing PUBG if this is an issue. Doesn't matter what settings you play on, there's nothing cooling the phone so all the heat is escaping out the back.
  19. W1540566609200
    Cupcake May 8, 2020
    W1540566609200 , May 8, 2020 :
    are you playing pubg and any other games in your op6?
    Artemus. likes this.
  20. W1540566609200
    Cupcake May 10, 2020
