208
  1. Artemus.
    Nougat May 10, 2020
    Artemus. , May 10, 2020 :
    Don't obsess with getting the most SOT and comparing it to others. As long as you used those four and a half hours to do what you wanted to do, that's your business.
    DevaDcruz likes this.
  2. mehra.savi
    Donut May 10, 2020
    mehra.savi , via OnePlus 6 , May 10, 2020 :
    my phone is getting over heated from last 5 days while doing video calls I don't know what's going wrong with the phone suddenly
    kindly advise ...
    R1538114086770 likes this.
  3. Artemus.
    Nougat May 10, 2020
    This is normal...
  4. M1564266186728
    Cupcake May 12, 2020
  5. Artemus.
    Nougat May 12, 2020
    Artemus. , May 12, 2020 :
    Video calling is the reason for your battery "issues". Also, wrong subforum.
  6. Varun yadav 1343
    Varun yadav 1343 , via OnePlus 6 , May 12, 2020 :
    I am using my phone normally and suddenly it gets switched off, before that a notification comes that this app(any app on my phone) is draining a battery, an alert notification comes and suddenly my phone gets switch off and after that my phone is heating a lot.
    It happens occasionally, once a month or once in 2 months.
  7. Cervantes
    Lollipop Moderator May 12, 2020
    Cervantes , May 12, 2020 :
    Hi
    what phone model do you have OP6 or OP6T
    Varun yadav 1343 likes this.
  8. Varun yadav 1343
  9. Cervantes
    Hi
    Please, check and use this thread for all battery questions
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz
    Use the search engine before opening a new thread
    Thread merged
    Artemus. likes this.
  10. Varun yadav 1343
    I don't know about this app or community app, can you please help, it happened again, I was just using my phone and suddenly it restarts.
    please help
  11. Cervantes
    as a solution can be suggested, we can't see your phone
    that's why I suggest you in my previous post: screenshots
    for another user to suggest: upload a screenshot of: settings, battery:
    battery and other
    battery uses
    cpuz downloads from play store
    Install cpuz: screenshot from: thermal
  12. Varun yadav 1343
    Cupcake May 13, 2020
    Varun yadav 1343 , via OnePlus 6 , May 13, 2020 :
    here are the screenshots
  13. Varun yadav 1343
    Also, I play pes on this mobile, but not for hours, I okay one game at a time after after some time I play another game. I do not play pes regularly.
  14. Artemus.
    Nougat May 13, 2020
  15. Varun yadav 1343
    Kytharsis
    What's wrong with your battery exactly?​
    actually nothing is wrong with my battery,
    my phone gets restart when I'm using any app,.and yesterday it happened 4 times, first when I was playing pes, second when I opened snapchat, third when I opened whatsapp, and 4 fourth while I was charging my phone
  16. Varun yadav 1343
    I am facing this issue suddenly, I uninstalled some apps which I have installed recently but what's the problem?
    This is happening after the update I got, I was not facing this problem in any other update.
  17. Artemus.
    Nougat May 13, 2020
    Artemus. , May 13, 2020 :
    When is the last time you wiped?
  18. Varun yadav 1343
  19. Artemus.
    Nougat May 13, 2020
    Wiped means factory resetting. You must do this at least once a year for maintenance purposes.
  20. Varun yadav 1343
    Never did that, I will lose all my data that's why
