208
  1. Artemus.
    Nougat May 13, 2020
    Artemus. , May 13, 2020 :
    And this is why you're having these kinds of issues. You can easily back up your data via Drive/Photos and retrieve them afterwards.
  2. Varun yadav 1343
    Cupcake May 13, 2020
    Varun yadav 1343 , via OnePlus 6 , May 13, 2020 :
    But earlier I was not facing this issue, yesterday it happened 4 times
  3. Varun yadav 1343
    Playing pes is an issue?
  4. Artemus.
    Nougat May 13, 2020
    Nope. But the issues you're having with the crashing and the heat-up. This is caused by incompatibilities left over from Android 9 and therefore a full wipe is necessary to clear these.
  5. G_Deep_Singh_HUbw
    Cupcake May 14, 2020
  6. Artemus.
    Nougat May 14, 2020
    Artemus. , May 14, 2020 :
    Yes... this is completely normal yet people still complain about it. PUBG is a horribly-optimized game and works the SOC to its limits. It's the same reason your PC gets loud when you're gaming except the phone has nothing to cool it inside so all the heat gets dissipated through the back.
  7. A1559670532895
    Donut May 18, 2020
    A1559670532895 , May 18, 2020 :
    Hi guys,
    I have a OP6 about two years old and since a couple of weeks battery has started to drain much faster than usual, not even 24h and around 3h of screen time. I'm wondering why can this be. First thought was Android 10, but perhaps is just the battery lifespan reaching to its end after two years.
    What are you experiencing? Is Android 10 draining your battery too? And has anyone reached the battery lifespan?
    Thanks in advance!
  8. Cervantes
    Lollipop Moderator May 18, 2020
    Cervantes , May 18, 2020 :
    Hi
    Please, check and use this thread for all battery questions
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    You can install cpu-z, which gives thermal report
    Use the search engine before opening a new thread
    Thread merged
    A1559670532895 likes this.
  9. matteo gioia
    Eclair May 20, 2020
    matteo gioia , May 20, 2020 :
    Hello guys, it's been a while now that my OP6 has suffered from overheatngs and restarts, approx. 2 weeks.
    I procedeed to do a full wipe twice and it still doesn't work. I am wondering if this is an hardware issue or an issue with the latest version. Heating is localized in the CPU as showed by CPU - z (battery is cool under 34 degrees celsius).
    I'll try rolling back to a previous version now.
    I'll keep you guys updated
    EDIT: i full wiped twice, roll back didn't seem to work at first but now I reinstalled latest update and phone is stable except for a few times where network deactivates because of the heat. I'm starting to believe that some app might be causing this.
  10. sagsingh
    Cupcake May 22, 2020
    sagsingh , May 22, 2020 :
    Facing the exact same issue. I mostly use some social media and camera. But the lag as well as battery drain, along with the heat up is very evident as i havent seen those issues before the update. Not sure how to get it resolved or go back to the previous working update
  11. Caomhin
    Lollipop May 22, 2020
    Caomhin , via OnePlus 6T , May 22, 2020 :
    Have you tried the suggestions further up the thread on Optimising phone and battery?
  12. iamthespeedster
    Cupcake May 23, 2020
    iamthespeedster , via OnePlus 6 , May 23, 2020 :
    Hi , i have been using one plus 6 prety long and in all those days i never had battery drain problems or heating issues until the update 10.3.3. Not sure why but its been few days i noticed that the battery is draining of quickly and i have been facing heating issues while playing games like Call Of Duty. Never i had this problem before. Can anyone advise what can be done in such case.
  13. Artemus.
    Nougat May 23, 2020
    Artemus. , May 23, 2020 :
    You can... show us the thermals via CPU-Z.
  14. 09sailesh
    Cupcake May 24, 2020
    09sailesh , May 24, 2020 :
    hey there,
    my op6t is getting heated without any use and battery is draining very fast.
    is this due to update or any other issue
  15. Artemus.
    Nougat May 24, 2020
    Artemus. , May 24, 2020 :
    Again, CPU-Z.
  16. 09sailesh
  17. Artemus.
    Nougat May 24, 2020
  18. 09sailesh
    Kytharsis
    HOLY CRAP. Do you have multiple games running in the background and expect them to not run? o__O​
    i have no games running in background
    from yesterday it's been like this
  19. 09sailesh
    from yesterday it's been like this.
    Any battery issue or hardware issue
  20. Artemus.
    Nougat May 24, 2020
    What apps are you using?
