213
  1. Caomhin
    Marshmallow Aug 13, 2020
    Caomhin , via OnePlus 6T , Aug 13, 2020 :
    Nothing to worry about, I am at 82% after 20 months on 6T. Still get up to 10 hours SOT. Phone functions fine.
    You should be good for another couple of years.
    sandro87 and drl431 like this.
  2. W1535868078507
    Froyo Aug 18, 2020
  3. drl431
    Nougat Aug 18, 2020
    drl431 , Aug 18, 2020 :
    After a system update, allow 2 or 3 full battery cycles for things to settle down. Also charge the phone overnight, at least occasionally, to allow the system to calibrate for battery usage.
  4. W1535868078507
    Froyo Aug 18, 2020
    W1535868078507 , Aug 18, 2020 :
    if we charge the overnight battery may burst or life may decrease
  5. drl431
    Nougat Aug 18, 2020
    LoL, that sounds like an old wives tale.
  6. W1535868078507
    Froyo Aug 19, 2020
  7. Shiv_Raj2304
    Cupcake Aug 19, 2020
    Shiv_Raj2304 , Aug 19, 2020 :
    My SOT is very low, at around 3 hours maximum.
    I'm thinking of getting a battery replacement.
  8. Shiv_Raj2304
    Download the apk of One Plus Diagnostic app. Search for it on Google you can find it easily.
    Then install it. Click on View Battery Status.
  9. W1535868078507
    Froyo Aug 19, 2020
    W1535868078507 , Aug 19, 2020 :
    OnePlus care or one plus diagnostic
  10. Shiv_Raj2304
    Oneplus diagnostic. It is not on the Play Store. You need to install it through the apk file.
  11. W1535868078507
    Froyo Aug 19, 2020
    ok I got 79% of it
  12. Shiv_Raj2304
    Same here. How much Screen on time do you get?
  13. W1535868078507
    Froyo Aug 19, 2020
    30 secs for screen time out
  14. Shiv_Raj2304
    No no. That's not what I'm asking.
    In the settings, go to battery.
    This is the Screen On Time.
  15. W1535868078507
    Froyo Aug 19, 2020
  16. Shiv_Raj2304
    Exactly. This is what I'm talking about.
    You charged 24 hours ago and with 6 hours of screen on time your battery is still at 84%. Mine is 78% with only 41 mins of screen on time.
  17. W1535868078507
    Froyo Aug 19, 2020
    i charged my phone 89% after 2 hrs it get reduced to 85% in IDLE condition itself
  18. Shiv_Raj2304
    Please can someone help.
    is this normal? if I add up the battery consumption by each app or service, it goes around 20%. but my battery has depleted by more than 40%. I have been getting very low SOT of around 3 hours.
  19. Caomhin
    Marshmallow Aug 19, 2020
    Caomhin , via OnePlus 6T , Aug 19, 2020 :
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Batter Drain.
    drl431 likes this.
  20. sandro87
    Donut Aug 19, 2020
    sandro87 , Aug 19, 2020 :
    I seriously wonder how people get 10h of SOT. I have the OP6 since April 2019 and I'm already at 81% status which makes sense considering the shelf capacity loss from 2018 and my usage (charging everyday). However I never had a particular high SOT. And I'm really not a heavy user. I don't play games or use socials. My usage is Chrome, Telegram and YT, that's it. My SOT is 3:30h/4h at max.
    Since people get 10h of SOT with the same capacity I have I find a battery replacement a waste of money.
    Also I wanted to do it myself to save money but batteries aren't sold by OP officially so I'm scared the ones you find online are bad quality or already too old.
    Amanrae likes this.
