228
  1. H1526983503749
    Cupcake May 23, 2018
    H1526983503749 , May 23, 2018 :
    are you using the charger included?
  2. Terryruiz
    Ice Cream Sandwich May 23, 2018
    Terryruiz , May 23, 2018 :
    if you look around the OnePlus 6 forum ....sound ..camera.. battery ..WiFi ...4g ..charging.... problems Not a good start for the OnePlus 6
  3. H1526983503749
    I've used the phone and have found none of the above problems [e]1f64c[/e]
    don't base your judgement on what haters say...base your judgement after using the device [e]1f64c[/e]
    NateDev and divyanshusaini95 like this.
  4. tempest301
    tempest301 , May 23, 2018 :
    I purchased the OP6 at a popup, charged to full and I am currently getting 48 hours of charge with moderate use - email and music and texting.
    H1526983503749 likes this.
  5. Terryruiz
  6. Terryruiz
  7. Liehjan
    Marshmallow May 23, 2018
  8. G1526965676825
    G1526965676825 , May 23, 2018 :
    yes I m charging from one plus charger.Why would I charge from different cable if it's a dash charging
  9. H1526983503749
    what do you even mean by this...OP5, OP5T and OP6 have the same 3300Mah battery...if you don't have a problem with OP5 why do you have one with OP6
  10. Terryruiz
    how can a new phone with bigger screen have same battery as a one year old phone 5.5 screen OnePlus 5
  11. F_Shiva_Tink_jzUA
    Froyo May 23, 2018
    F_Shiva_Tink_jzUA , May 23, 2018 :
    i really dont underst how much mah battery need for the phone ? to me op6 battery was too gud when coming frm 3t....
  12. Terryruiz
    don't care about 845 processer ... I've had mobiles for years it should if put a bigger battery in the oneplus 6
  13. Terryruiz
  14. Terryruiz
    I've a OnePlus 5 ...all I can say about the OnePlus 6 is the battery is same as mine 3300 and is smaller then the old OnePlus 3t which was 3400 ....with a bigger screen they should of put a bigger battery inside ....
  15. maxxam23
    maxxam23 , May 23, 2018 :
    OP2 was an unfortunate model. Tech has improved a lot since OP2. If you are person who is a heavy user and also stays away from power plugs for long, you should consider phones like MI Max of Asus with 5000 mAH batteries. But those phones dont carry flagship SOCs so there's that.
  16. guisbro
    guisbro , May 23, 2018 :
    Those who have provided data seem to be suggesting the OP6 has a good-very good battery life. Sounds like about 50% better than my OPX.
  17. taran3105
    Donut May 23, 2018
    taran3105 , May 23, 2018 :
    I got my Oneplus 6 yesterday. But my phone got switched off automatically at 70 percent. When i tried to switch on it showed me "Low Battery put it on charge" error. Should i replace the product or not ?
    mthumar likes this.
  18. W1519712713652
  19. taran3105
    Donut May 23, 2018
    Now the phone has started and is charging from zero. Also i have installed the latest update. Would the update will make any difference or not ?
  20. W1519712713652
