228
  1. Dexxagon
    Honeycomb Oct 24, 2020
  2. K1544273315759
    Cupcake Oct 27, 2020
    K1544273315759 , Oct 27, 2020 :
    Same thing here. Had the google play services issue at the beginning of september 2020. Tried a lot of things but nothing really worked out. Issue kinda went away by itself afterward.
    Now Since october 25 2020, the huge battery drain is back. The battery is being drained only when wifi or data is on. Everything seems to be fine when wifi and data are off. Google Play Service battery usage can go as high as 20-30% and phone has to be charged up a couple times a day.
    Before that I used to be able to do ~1,5h youtube during my subway commute without concern about the battery at all, with ample battery margin back at home in the evening.
    The battery drain is still present even in safe mode
    , which makes me think it has nothing to do with 3rd party apps.
    As for now I'm using the phone without any data which is not what anyone expects to do with a OnePlus 6. Phone has been bought on May 2019 so it's not that old.
    Any help, tips or advice appreciated !
    Carlos_Leonel likes this.
  3. Raza_Dawar
    Froyo Oct 28, 2020
  4. Deepakdkp
    Honeycomb Oct 28, 2020
    Deepakdkp , via OnePlus 6 , Oct 28, 2020 :
    Check if there is sync issues
    Maybe back up is not getting synced properly or some photos or videos.
    You may clear cache and clear storage for
    Google framework
    Google app
    Google Chrome
    Playstore
    Google Play services.
    Restart your phone. And give it a day or two. Then check again.
  5. Sudhakarbabu.T
    Cupcake Oct 29, 2020
  6. Sudhakarbabu.T
  7. maxjustinnick
    maxjustinnick , via OnePlus 6 , Oct 29, 2020 :
    Hi all,
    I've been experiencing issues with my One Plus 6 (from Jul '18) where my battery suddenly drops from 50%/60% to nil. Does anybody know what might be causing this and if there is anything I can do about it?
    Thanks!
    Max
  8. Raza_Dawar
    Froyo Oct 29, 2020
  9. Namimodi.nm , via OnePlus 6T Mirror Black , Oct 30, 2020 :
    You can try few things like
    Turn on the battery optimization for some apps which u dont frequently use
    Then use your phone in dark mode
    Try deep clear data also
    This things will help reduce battery drainage nd all
  10. Niloy02
    Cupcake Oct 30, 2020
  11. G1528206711825
    G1528206711825 , Oct 30, 2020 :
    Battery is draining to fast on my oneplus 6, when I turn of bluetooth. It is taking only 15 mins to drain 50% of phone battery. Need software optimization ugently.
  12. Muhammad_Kashif_bahl
    Honeycomb Oct 31, 2020
  13. Muhammad_Kashif_bahl
    Muhammad_Kashif_bahl , via OnePlus 6 , Oct 31, 2020 :
    Close or force stop all installed apps.
  14. Muhammad_Kashif_bahl
    Close or force stop all aap installed in you phone then restart.. you will feel no battery heating issue..
  15. Muhammad_Kashif_bahl
    Check bluetooth setting ad device are which you are connecting is discoverable
  16. Sudhakarbabu.T
    Cupcake Oct 31, 2020
  17. Kirans499
    Froyo Oct 31, 2020
