240
  1. Onlymewithall
    Eclair Apr 10, 2021
  2. Saurav_Mahato
    Donut Apr 10, 2021
  3. Dhruvrawal
    Froyo Apr 10, 2021
  4. Onlymewithall
    Eclair Apr 11, 2021
  5. YSRReddy
    Honeycomb Apr 12, 2021
  6. Varun@02 , via OnePlus 6 Mirror Black , Apr 19, 2021 :
    If you are facing the battery issue try to use your device in lower brightness as much as possible and keep the device in battery saver mode as much as possible as it will restrict background access to app. Clean the cahe .and restrict the background access of the apps.
  7. Bobbie63
    Marshmallow Apr 20, 2021
    Bobbie63 , Apr 20, 2021 :
    The more stuff you put in a phone, like bigger sensors and stuff, the smaller the batteries get. Can't have it all, there's a limitation to the space.
    Also, if you buy a phone and you want a bigger battery, check the specs before buying one maybe?
  8. Shaifi007
    Cupcake Apr 22, 2021
  9. iamrj
    Ice Cream Sandwich Apr 22, 2021
    iamrj , via OnePlus 6 , Apr 22, 2021 :
    Hey there! I have noticed after updating the latest version of oxygen os my battery is draining 🔋
    Before battery usage
    After battery usage
    After testing just see the difference between both
    It is over heated and I have to charge my device more then thrice in a day when it was newly my battery last atleast one whole day when android 8 was realised after new updates battery is very annoying and weird 🙈
    Note: I have took backup reset bit nothing happened when we had os 10.3.5 it was draining and heating 40°C for few days then I had to switch off my phone atleast for 45 minutes then it becomes normal yet today it is not that great.
    Can these developers can fixed these issues I request they can do the needful in upcoming ota updates
    Cheers!
    YSRReddy likes this.
  10. sumitMZ007
    Jelly Bean Apr 22, 2021
  11. B1618877476042
  12. Ewan_Whyte
    Ewan_Whyte , Apr 22, 2021 :
    Wiped my phone. Battery drain still bad.
    Either my phone is packing up OR a deliberate battery draining update has been deployed by OnePlus.
    I'm starting to think they're like the Super League of football trying to force people into taking part.
  13. YSRReddy
    Honeycomb Apr 23, 2021
    iamrj likes this.
  14. pablofg1978
    Head Moderator Head Moderator Apr 23, 2021
    pablofg1978 , Apr 23, 2021 :
    Thread merged
  15. iamrj
    Ice Cream Sandwich Apr 23, 2021
    iamrj , via OnePlus 6 , Apr 23, 2021 :
    It's okay but issues is yet there on device, you can't change the facts on device even latest OP 9 series are having the same situations as other models are having .
  16. RealAman_01
    Froyo Apr 26, 2021
  17. Karthik Raaja
    Cupcake Apr 30, 2021
