240
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 30, 2021
    Caomhin , via OnePlus 9 Pro Pine Green , Apr 30, 2021 :
    Usually Software, but can be either or.
    the way you use the phone (daily usage scenarios and habits) will make a huge difference to the battery/heating performance. In a scenario where there is a heavy performance workload, such as photo shooting/video shooting/mobile gaming/video consumption, the power consumption and heating of the phone will increase accordingly, which is a normal phenomenon.
    There are also many other factors that can affect battery and heat, even ambient air temperatures above 25°c+ can slow down charging or cause heat issues, as the air temperature gets hotter the phone cannot dissipate heat as quickly so may even slow the charging down as a safety measure as well.
    Battery Facts by @TheMystic
    https://forums.oneplus.com/threads/battery-facts.995140/
    Guide to lower Battery Drain.
    Here are some tips to Optimise the use of your phone. This may help with many phone issues.
    By @TheMystic
    https://forums.oneplus.com/threads/updated-2021-setting-up-your-phone-for-best-experience.1415175/
    TheMystic likes this.
  2. Karthik Raaja
    Cupcake Apr 30, 2021
    Karthik Raaja , Apr 30, 2021 :
    My usage is not much and My phone is getting overheated mainly during charging and charging rate also got slower because of heating
  3. Caomhin
    Try the info in the links above and see if any of the steps in there can help.
  4. goodboyamit
    Cupcake May 1, 2021
    goodboyamit , via OnePlus 6 , May 1, 2021 :
    Hi,
    I recently got the battery of my OnePlus 6, replaced at OnePlus service center and got a software update there too, however, post that I have noticed that my phone is always a bit warm and I am facing the issue of battery drain.
    Any suggestions
  5. kalgecin
    Eclair May 1, 2021
    kalgecin , via OnePlus 6T , May 1, 2021 :
    Do you use 9gag? Apparently they crypto miner in the background. Makes the phone get hot. I uninstalled it and my phone has been done so far
  6. Cervantes
    Moderator Moderator May 1, 2021
    Cervantes , May 1, 2021 :
    Hello
    Please, Use the search engine before opening a new thread: Search
    use the battery thread for battery and heating problems: Here
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz: check temperature
    Read the forum rules: Rules
    Thread merged
  7. goodboyamit
    Cupcake May 2, 2021
    goodboyamit , via OnePlus 6 , May 2, 2021 :
    The thread you are referring to are more than 3 years old, how can sharing a link of that help me, also what makes you think they ib didn't try the things referred in those links before posting. I have been a community member for a long time now to know about the guidelines. How can you close my thread saying that it violates community guidelines.
  8. goodboyamit
    Cupcake May 2, 2021
    Thanks for responding, no I haven't installed any crypto miner
  9. Cervantes
    Moderator Moderator May 2, 2021
    Cervantes , May 2, 2021 :
    This thread is 3 years old and has information on how to solve battery problems
    screenshots help to:
    Battery: show which app consumes more battery
    cpuz: shows what temperature is the phone
  10. L1563202903538
    Cupcake May 3, 2021
  11. riyankgangawat
    Donut May 11, 2021
  12. V1529311564432
    Cupcake May 17, 2021
  13. NJM97
    Cupcake May 23, 2021
  14. oneplusfav4ever
    Ice Cream Sandwich May 23, 2021
  15. Vicky_Raga
    Cupcake May 26, 2021
    Vicky_Raga , May 26, 2021 :
    I have a question that is normal and that with a new phone, if something like this happens to me with the battery where can I turn.
