250
  1. oneplusfav4ever
    Ice Cream Sandwich May 27, 2021
  2. chowdhuryriham
    Cupcake May 28, 2021
  3. O1622566963316
    Cupcake Jun 1, 2021
  4. Mr.Steve
    Gingerbread Jun 2, 2021
    Mr.Steve , via OnePlus 6 , Jun 2, 2021 :
    If your device is more than 2 years old and you experience this frequently. The only best option would be a new battery !!
    Plus , over the last one year software updates , the oneplus 6 standard SOT rate has been drastically reduced.
  5. Vedseroz
    Cupcake Jun 7, 2021
    Vedseroz , Jun 7, 2021 :
    I changed my OnePlus 6 battery a week ago, and after the change I tried to calibrate again my battery. At first I thought that I actually did, but now when I reach 20%, my phone dies.
    I try to turn it on, but then it shows a warning showing "Battery too low to turn on".
    As you can see in the picture, there is a serious discontinuity when I reach 20%.
    Any advice?
    p.s: I bought the replacement battery on Ali because I got this phone on the US and I'm from Chile, and in this country there is 0 support for this phone.
  6. ItsRavi25
    Jelly Bean Jun 7, 2021
    Caoimhín likes this.
  7. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 7, 2021
    Shailender Sharma likes this.
  8. Vedseroz
    Cupcake Jun 7, 2021
  9. pablofg1978
    Head Moderator Head Moderator Jun 7, 2021
    pablofg1978 , Jun 7, 2021 :
    Thread merged
    Caomhin likes this.
  10. M1607923550582
    Cupcake Jun 8, 2021
  11. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 8, 2021
    Caomhin , via OnePlus 9 Pro , Jun 8, 2021 :
    Battery looks good
    Guide to lower Battery Drain.
    Here are some tips to Optimise the use of your phone. This may help with many phone issues. By @TheMystic
    https://forums.oneplus.com/threads/updated-2021-setting-up-your-phone-for-best-experience.1415175/
    M1607923550582 likes this.
  12. yash00012
    Honeycomb Jun 10, 2021
  13. kumarmanoj396
    Donut Jun 10, 2021
  14. A1572025529614
    Cupcake Jun 10, 2021
    A1572025529614 , via OnePlus 6T , Jun 10, 2021 :
    1. Use dark theme.
    2. Use battery Optimisation enable for all Apps.
    3. Use deep clear in Setting->Advanced->Recent App Management->Deep Clear.
    4. No extra UI App and can also use a dark wallpaper for both home and lock screen.
    5. Face Unlock-> I dont think of its much use, also not very secure. Its always run in background and eating Ram and battery, so u can also disable it.
  15. rishabhj146
    rishabhj146 , via OnePlus 6 , Jun 10, 2021 :
    I update 10.03.11
    After update
    I am unable to see Whatsapp Media in Gallery
    I activate Whatsapp media visibility
    Than also I am unable to see Whatsapp Media
  16. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 10, 2021
    Caomhin , via OnePlus 9 Pro , Jun 10, 2021 :
    WhatsApp has changed the path where to save images, videos, GIFs, audio, documents and stickers on WhatsApp for Android.
    Step 1
    https://wabetainfo.com/how-to-fix-missing-media-on-whatsapp-for-android/
    Step 2
    https://wabetainfo.com/how-to-restore-the-media-visibility-on-whatsapp-for-android/
  17. YSRReddy
    Honeycomb Jun 18, 2021
  18. shubham2104
    Cupcake Jun 19, 2021
    shubham2104 , Jun 19, 2021 :
    After the latest update 10.3.11, the battery has started draining substantially even if the device is not in use for hours. I even restricted the background usage of all the apps, that didn't work. I did a factory reset, even that didn't help. Everything was fine before the update. It is very disheartening to see, OnePlus cannot provide stable updates or is it just doing this deliberately pushing us to get new devices. Nobody is going to get a new OP device if you're pushing such buggy updates to your devices.
  19. Mohasin_MK
  20. drl431
    Community Hero 2020 Jun 19, 2021
    drl431 , Jun 19, 2021 :
    Hi, that depends on the apps you have installed, or if you transferred apps from an old phone.
    ItsRavi25, buntycubal and Mohasin_MK like this.
