182
  1. Q1527619817177 Froyo Jun 3, 2018
    Q1527619817177, Jun 3, 2018 :
    can u send the graph and the battery usage
  2. Gopiteja Donut Jun 3, 2018
    Gopiteja, Jun 3, 2018 :
    battery also gets better with standby. after few days?
  3. G_Markel_Iglesias_Sanche Cupcake Jun 3, 2018
    G_Markel_Iglesias_Sanche, Jun 3, 2018 :
    How many hours of sot you get?
  4. abhiram_kr Cupcake Jun 3, 2018
    abhiram_kr, Jun 3, 2018 :
    I easily get one day backup after a morning routine charge. J am attaching the screenshot in the next reply. Wait.
  5. Gopiteja Donut Jun 3, 2018
    answer my question which is above
  6. abhiram_kr Cupcake Jun 3, 2018
    Battery should be good after 2-3 days of usage. Initially it will drain up cause first time system set up and play services. After heavy usage you should get a day's backup easily.
  7. abhiram_kr Cupcake Jun 3, 2018
    Here is my battery usage graph and details after last charge which was yesterday evening.
  8. Naveen chaganti Cupcake Jun 3, 2018
  9. Gopiteja Donut Jun 3, 2018
    how much % battery gets done depleted after 8h standby ?
    if u didn't check .Take screenshots before going to sleep and after u woke up
  10. A1528006262471 Cupcake Jun 3, 2018
  11. abhiram_kr Cupcake Jun 3, 2018
    Around 8-10 %, when my mobile data and location services are on.
  12. Gopiteja Donut Jun 3, 2018
    when those are off
  13. Naveen chaganti Cupcake Jun 3, 2018
  14. chrismonoyios Cupcake Jun 3, 2018
    chrismonoyios, Jun 3, 2018 :
    I have been using OP6 for 3 days now alongside OP5T. Battery of OP6 is depleting a lot faster. In a days use with the exact same settings and usage OP6 drops to 20 to 25% while OP5T ranges from 60 to 65%.
    Any one has any ideas here? The difference is enormous.
    Note. I did try to wipe out cache with no difference
  15. Nits_G_ Eclair Jun 3, 2018
    Nits_G_, Jun 3, 2018 :
    ya this is a bug and my phone is also draining very fast.
    hope it will be fixed
  16. Jack4001 Froyo Jun 3, 2018
    Jack4001, Jun 3, 2018 :
    can you share screenshot, I m sharing mine , I have two days record of battery performance, if some more ppl join we can know how much battery lasts in an average
  17. Nits_G_ Eclair Jun 3, 2018
    Jack4001 likes this.
  18. Jack4001 Froyo Jun 3, 2018
    same as me, my on screen time is about 6 hrs while I use data and some other stuff and not playing a single game but yes hotspot sometimes, over WiFi connection I get about 7.5 hrs on screen time
    stevenliu12 likes this.
  19. Nits_G_ Eclair Jun 3, 2018
    Prsdbuzzi and Jack4001 like this.
  20. Jack4001 Froyo Jun 3, 2018
    hopefully yes
