223
  1. PoinP
    Froyo Jun 3, 2018
  2. gubro
    KitKat Jun 3, 2018
    gubro , Jun 3, 2018 :
    What is "camparre "?
  3. Terryruiz
    Ice Cream Sandwich Jun 3, 2018
  4. PreetishSankhua
    Cupcake Jun 3, 2018
  5. Terryruiz
    Terryruiz , Jun 3, 2018 :
    so all depends how you use your new OnePlus 6 ...if you had a 5 or 5T before and use it the same way your battery life will be less ...on the OnePlus 6 as all have the same battery size 3300
  6. M1528042880961
    Eclair Jun 3, 2018
    M1528042880961 , Jun 3, 2018 :
    I have a same issue if battery draining very fast and dash charge takes 1 hour to complete 1 to 100% pls adive
  7. mosyn2k
    Froyo Jun 3, 2018
    mosyn2k , Jun 3, 2018 :
    I have the same issue I charge it to 100 before bed when I wake up it drains like 20 percent on my op5 I was getting 5 hrs sot at 50 percent
  8. Terryruiz
    because both have same battery inside and oneplus 6 is 6.3 screen ... OnePlus 5 is 5.5 screen
  9. mosyn2k
    Froyo Jun 3, 2018
    but it shouldn't drain 20 percent
  10. Prakashranjangupta
    Cupcake Jun 3, 2018
    Prakashranjangupta , Jun 3, 2018 :
    me too facing the same problem...
  11. Terryruiz
    Come on people ....you have to see it if you had the OnePlus 5 and buy the OnePlus 6 .... SOT will be worse on the OnePlus 6 ...if you use the 6 the same as the 5 ....as the battery is same size in both phones 3300....one has 6.3 screen one has 5.5 screen
  12. Terryruiz
  13. siddharth740
    Gingerbread Jun 3, 2018
    siddharth740 , Jun 3, 2018 :
    My Phone Is Also Draning Fast While Playing Game It consumes too Much battery.
    even i m not using WiFi tha wifi uses 3 4% battery without use
    i have to charge my phone 2 times a day
  14. B1527431838214
    Cupcake Jun 3, 2018
    B1527431838214 , Jun 3, 2018 :
    B1527431838214
    Battery backup relatively low... not enough battery for 6+ inch screen. tried all suggestions to optimise before posting.. but not satisfied with battery backup.
    Another issue phone getting heated up, perticularly Even with small data transfer (didn't consider while charging).
    only one game installed (bubble shooter) just to check/ confirm both issues..​
    one of my worst battery figures
    Terryruiz likes this.
  15. Terryruiz
  16. Terryruiz
    B1527431838214 likes this.
  17. U1513149367412
    Honeycomb Jun 3, 2018
    Prakashranjangupta likes this.
  18. Madhan8
    Eclair Jun 3, 2018
    Madhan8 , Jun 3, 2018 :
    here too good
  19. Aparna_Gudlavalleti
    Cupcake Jun 3, 2018
    Aparna_Gudlavalleti , Jun 3, 2018 :
    I am also facing the same issue.i charged my mobile in the morning today and now only 48% is left.i don't play any games.
  20. Phillbert0
    Eclair Jun 3, 2018
    Phillbert0 , Jun 3, 2018 :
    I'm having the same issue. If I reboot the phone in the morning, it seems great for most of the day. If I don't though, battery life is pretty bad.
    It's weird because until I figured this out, I'd get 7 hours screen on time, then the next day I'd get 2. Man was I confused!
    Almost all of my usage is on Wi-Fi. Only use GPS when opening weather. Screen brightness is very low. And I have very very few apps, only 9 non-stock apps. Things like Feedly, and a calculator - not exactly battery hogs.
