22
[UNIFIED] Op6t battery and heating thread
  1. M1541510823291
    Cupcake Nov 5, 2019
  2. F_Hamza_Younis_Boey
    Cupcake Nov 6, 2019
    F_Hamza_Younis_Boey , Nov 6, 2019 :
    After the latest OS update on my OP6t im loosing to much battery at night while im sleeping i lost almost 40perc charge i think my standby mode is not working. Any solutions ?
  3. Leandro161288
    Froyo Nov 7, 2019
  4. chinovilla
    Cupcake Nov 8, 2019
    chinovilla , Nov 8, 2019 :
    From 2-3 weeks, my oneplus 6t McE drains the battery in half the time than before. Help
  5. arthur74
    Cupcake Nov 9, 2019
    arthur74 , Nov 9, 2019 :
    oneplus 6t oxygenos 9.0.17 heat battery drain issues since 3-4 days.
    my oneplus 6t drains the battery in LESS than half the time than before.
    I restarted my device. Didn't help. Perhaps issues began after Update to Oygenos 9.0.17.
    Did not found any help.
    How can i calibrate my device? Does this help?
    Any suggestions?
    When does the next updite arrive?
    Please help!
  6. msaia
    Cupcake Nov 10, 2019
    msaia , via OnePlus 6T , Nov 10, 2019 :
    So upgraded to a10 and battery life is horrible. Not bad, horrible. I forgot to take a screen shot so I will tomorrow but my SOT is the last two days was 1 how 37 mins with 8% left and 2 hours 18 mins with 12% left.
    What the hell?
  7. ucheni
    Donut Nov 10, 2019
    ucheni , Nov 10, 2019 :
    Hello,
    For about two weeks or so my OnePlus 6T runs out of battery very fast.
    Before that, and with the use that what I give to the phone, I arrived at the end of the day with a 50% battery, and now I don't finish the day !!
    I have version 9.0.17.
    Any solution? Any ideas or suggestions?
    Thanks in advance.
    arthur74 likes this.
  8. krakera
    Donut Nov 10, 2019
    krakera , Nov 10, 2019 :
    Hi community
    I would not make this thread if someone answered my problem with google service.
    I have huge battery drain from "Google Play Service ". It's from 50-70 % to the end of the day.
    If someone can help this would be great.
    I have trayed:
    1- Hard reset phone 3 times didn't work.
    2- Clearing cache files from the settings and from the bootloader (didn't forget to reset the phone ) didn't work.
    3*- Run the phone-in save mod problem was gone the phone lasted 4 days.
    4- Deleted all apps except FB messenger didn't work.
    5- Stopped "Play Store" automatick updating on apps. (worked for 1 day. The next day was back to the same battery drain over 50 %)
    6- Stopped auto-sync data. It didn't work. (I have only 1 G-acc.)
    7- Restricted "Play Service" from GPS/Bluetooth/Wi-Fi didn't work.
    8- Stoped using Wi-Fi and /Bluetooth for a week didn't work.
    9- Tried running Facebook Lite (one of the community wrote to my post )
    The problem starts to occur when the phone is under 80 % battery. When the phone is fully charged the problem resets 100 % after it.
    Please READ before committing me to do the same stuff !!!
  9. Mayank_yadav_2628
    Cupcake Nov 11, 2019 at 5:37 AM
  10. Mayank_yadav_2628
    Cupcake Nov 11, 2019 at 5:38 AM
    Mayank_yadav_2628 , via OnePlus 6T , Nov 11, 2019 at 5:38 AM :
    I've been experiencing affected battery life after the latest android 10 update on my Oneplus 6t. The screen on time is drastically reduced and the phone also gets heated up after few minutes of gaming. Please do the needful to solve the problems.
  11. Luukdewit
    Cupcake Nov 11, 2019 at 3:36 PM
    Luukdewit , Nov 11, 2019 at 3:36 PM :
    For 2a3 weeks it feels like my battery is just leaking power.... normaly after a day work i would get home with a minimum of %50... Now its already there at break time on half of the workday... nothing in my phone use has changed
    Op6t 9.0.17
    Edit: Top part of phone heats up while charging
  12. JeleznyBo
    Cupcake Nov 11, 2019 at 4:06 PM
    JeleznyBo , Nov 11, 2019 at 4:06 PM :
    Всем привет, мой телефон OnePlus 6T. После установки через Oxygen Updater Android 10 (Oxygen 10.0) телефон стал очень быстро разряжаться и греться. Такого раньше на Android 9.0.1 не было. Прошу разработчиков ПО компании разобраться с проблемой и устранить её.
    Привет всем, мой телефон OnePlus 6T. После установки через Oxygen Updater Android 10 (Oxygen 10.0) телефон начал очень быстро разряжаться и греться. На Android 9.0.1 такого раньше не было. Я прошу разработчиков программного обеспечения компании решить проблему и устранить ее.
  13. KevinM23
    Donut Nov 11, 2019 at 4:27 PM
  14. krakera
    Donut Nov 11, 2019 at 5:07 PM
    krakera , via OnePlus 6T , Nov 11, 2019 at 5:07 PM :
    Hey man I have battery drain problems ,wrote like 5 times ..(the answer was none). When a new phone like 7 or 7t comes they ditch us the previous owners . I wrote in new trend for my problem they took it down and wrote me to do the same thing I did above in the tread I wrote . ( they don't even bother reading it ....) That's the community ...
  15. Roman_Vidales
    Cupcake Nov 11, 2019 at 10:07 PM
    Roman_Vidales , Nov 11, 2019 at 10:07 PM :
    Hello! I don't know if you did this, but I had a similar problem in 9.0.17 and the solution was to use the Google services beta, maybe it will help you
  16. krakera
    Donut Nov 11, 2019 at 10:47 PM
    krakera , via OnePlus 6T , Nov 11, 2019 at 10:47 PM :
    I heard it was getting worse I'll try it ...
  17. 11clav77
    Cupcake Nov 14, 2019 at 8:30 AM
  18. KevinM23
    Donut Nov 14, 2019 at 8:34 AM
    KevinM23 , Nov 14, 2019 at 8:34 AM :
    Hi,
    I found the solution for the problem. The issue is caused by Whatsapp. You need to update your whatsapp manually to the newest version which can be downloaded here:
    https://www.whatsapp.com/android/
    Download whatsapp from there, install it and the battery issues will be gone. I did this yesterday and after the update the battery works normally again. After 8 hours sleeping with the phone on, it went from 100% to 95% instead of 100% to 60% so the problem seems fixed.
    I hope this helps more people!
    11clav77 likes this.
  19. 11clav77
    Cupcake Nov 14, 2019 at 8:57 AM
    11clav77 , Nov 14, 2019 at 8:57 AM :
    I downloaded and installed this version of the app you suggest. I try in a next day to control the app battery usage.
    Thanks a lot. see you. bye bye
  20. F1573880148014
    Cupcake Nov 16, 2019 at 4:57 AM
    F1573880148014 , Nov 16, 2019 at 4:57 AM :
    Similar issue since the past one week, battery drains very fast.....was excellent in the first few months.... battery does not even last for 9 hours
