31
[UNIFIED] Op6t battery and heating thread
  1. F1573880148014
    Cupcake Nov 16, 2019
    F1573880148014 , Nov 16, 2019 :
    I'm experiencing the same issue
  2. F1573880148014
    one plus 6T version 9.0.17....past few weeks battery drains very fast....had a full charge at 8am down to 70% at 10am....no heavy usages
    P1570960479434 and Friz28 like this.
  3. clrrr
    clrrr , Nov 16, 2019 :
    I'm having this same problem
    op6t Android 10 - only 4h/5h of screen time
    FRUSTRATING
  4. Friz28
    Cupcake Nov 18, 2019
    Friz28 , Nov 18, 2019 :
    WhatsApp is draining all my battery!
    I have noticed that lately the message app is consuming a lot of battery and I can't use it anymore since I have difficulties in arriving at midday.
    Does anyone know why and/or has any suggestion?
    Thanks!
    clrrr likes this.
  5. FreekHelm
    Cupcake Nov 20, 2019
    FreekHelm , Nov 20, 2019 :
    I'm having the same problem since a week or two, battery drains a lot faster than before. Bought my Oneplus 6T about half a year ago. Still running Android 9.
  6. kvladan
    Eclair Nov 21, 2019
    kvladan , via OnePlus 6T , Nov 21, 2019 :
    I want to know how to charge battery on my OnePlus 6T ?
    Some people tell me about 5% to 100% , some people told me to charge battery between 35 to 90%.
    I asking that becouse I don't want to reduce a battery life.
  7. kvladan
    Eclair Nov 21, 2019
  8. human75
    Cupcake Nov 21, 2019
    human75 , Nov 21, 2019 :
    I have a big issue with WhatsApp up as well. typing becomes very unresponsive and display acts strange. once i sent WhatsApp back all turns normal. also, Whatsapp drains too much battery. especially after android 10 upgrade
  9. C1544392567110
    Cupcake Nov 23, 2019
  10. docans
    Donut Nov 24, 2019
    docans , Nov 24, 2019 :
    I have noticed that my battery totally drains in the morning when i wake up. I had about 40 percent of battery left when i woke up. I all got drained in a matter of 15 minutes till it shutdown. Can any one look into this
  11. arthur74
    Cupcake Nov 25, 2019
  12. M1531546196278
    Cupcake Nov 28, 2019
    M1531546196278 , via OnePlus 6T , Nov 28, 2019 :
    The same to me.
  13. Sidhaarth mutreja
    Gingerbread Nov 28, 2019
  14. B1572816084046
    Cupcake Dec 2, 2019
    B1572816084046 , Dec 2, 2019 :
    Hi, after updating my OnePlus 6t to Android 10, the battery drain was insane and lasted max 8hrs. Then I started to check my phone settings, I noticed that all applications had the location "allowed all the time". So changed only the important application to be allowed all the time and for rest of the applications I either denied or allowed only while in use. Huge change with the battery drain, now my battery last easily 25 - 30hrs. Hope this fix helps you as well.
  15. mgarg2
    Cupcake Dec 2, 2019
    mgarg2 , Dec 2, 2019 :
    I'm having this very same problem. I got my OnePlus 6T 4 days ago, it came with an old OxygenOS version as it had the 2018 August Android Security Patch and I was able to make it to 5 hours of Screen On Time. I updated to version 9.0.17 and I'm lucky if I make it past 3 hours of Screen On Time. I don't know what's happening but I would like to downgrade to another version. Is it possible?
  16. kvladan
    Eclair Dec 3, 2019
  17. mgarg2
    Cupcake Dec 3, 2019
  18. kvladan
    Eclair Dec 4, 2019
    kvladan , via OnePlus 6T , Dec 4, 2019 :
    I full battery of 35% to 90%. Do not wait to be emptied completely. Now I emptied to 17%. I maintain is always between 40 and 80%. If it has something to do. I do not know, maybe there is.
  19. kvladan
    Eclair Dec 4, 2019
  20. MskSrini
    Froyo Dec 6, 2019
    MskSrini , via OnePlus 6T , Dec 6, 2019 :
    At what percentage do you charge your phone?
    That may be the problem as when the automatically goes into battery saver mode is the ideal time to charge the and to not use it during the charging till 100%.
    If it still doesn't work then do the same while switch off phone it may work. It is not the way to charge the phone while switch off as it should charge while the phone is on.
    Even then it doesn't work then you should take it to a OnePlus service center.
    mgarg2 likes this.
