31
[UNIFIED] Op6t battery and heating thread
  1. Antipickle
    Cupcake Dec 12, 2019
    Antipickle , Dec 12, 2019 :
    I had amazing battery life.. And hadn't updated since springtime. Decided to start the updates up to the beta 10.30... Now it's like a Samsung phone 😂😂😂
    So it definitely has something to do with the updates this year.
    Some added feature is draining the battery. I don't know which update it started in because I did several updates at once.
    I did turn off location per app, all denied but some during use. Also turned off wifi and BT scanning under location, will post back if it helps any.
  2. kvladan
    Eclair Dec 15, 2019
  3. Faraz007
    Cupcake Dec 17, 2019
  4. Kytharsis
    Marshmallow Dec 17, 2019
    Kytharsis , Dec 17, 2019 :
    No such thing as "battery backup" as the phone only has a single battery.
  5. Aliasgar Jamali
    Cupcake Dec 18, 2019
    Aliasgar Jamali , Dec 18, 2019 :
    I'm still facing a battery drain problem after Andriod 10.1. Are there any services in the background whos consumption battery a lot ???
  6. S1548779240057
    Eclair Dec 22, 2019
  7. L1541392216427
    Cupcake Dec 23, 2019
  8. Abhishek20190
    Abhishek20190 , Dec 23, 2019 :
    I updated my oneplus 6T to Oxygen OS10.3.0 today, after update i am facing issue with the " Audio Tuner " under Sound Settings menu is not working, continously getting stopped on clicking!. Attaching Screenshot,
    Please oneplus team look into the issue
    I tried clearing cache and storage of "Dirac App "still problem persists.
  9. G_Marco_Iozzia_leys
    Cupcake Dec 25, 2019
    Aliasgar Jamali likes this.
  10. Rajath Kashyap
    Cupcake Dec 28, 2019
    Rajath Kashyap , via OnePlus 6T , Dec 28, 2019 :
    Hi,
    Am facing serious battery drain issues with my OnePlus 6T after updating to Android 10.3.0
    Kindly request OnePlus to look into this bug!!
    At 10 pm my phone's battery was - 100% when unplugged
    At 6.30 am with wifi, location,mobile data etc all turned off
    My battery percentage had dropped a significant amount and was at 79%
    When I checked in the battery section it showed Android System consumed so much in one night.
    Screen on time is also not more than 3.5hrs
    Before updating with same apps and same usage used to get almost 8 hours
    Kindly request OnePlus to look into matter!!
    Thank You
    MILIND.MEVADA likes this.
  11. tehdeejus
    tehdeejus , Dec 28, 2019 :
    My phone lasted 2 days before. The last 10 hours of the attached screenshot the phone was locked and not used. Seems the new update has made battery life less than half.
  12. Kytharsis
    Marshmallow Dec 31, 2019
    Kytharsis , Dec 31, 2019 :
    When did you update vs. when did you format/calibrate the battery?
  13. Ed Jones
    Froyo Jan 3, 2020
    Ed Jones , Jan 3, 2020 :
    I have a 6T McLaren. I was used to charging it every 3 days or so. I now have to charge it every day - even with little usage. The battery life used to be excellent and was one of the reasons I bought a OnePlus.
    This all started after the Android 10 and OS 10.3.0 updates.
  14. F1549216461987
    Cupcake Jan 3, 2020
    F1549216461987 , Jan 3, 2020 :
    Hi,
    After updated my one plus 6t to oxygen os 10.3.0 my mobile battery is draining so soon and sometimes if I open camera, a black screen appears later showing camera is in use and close automatically . when I choose potrait mode sometimes it quits automatically and came to home screen .
    Thanks in advance!!
  15. stinastina
    Cupcake Jan 4, 2020
    stinastina , Jan 4, 2020 :
    Hi
    Also having battery drain after 6T upgrade to 10.3.0. Second problem is that phone gets really hot while using Android Auto. I didn't have any heating problem before upgrade - even after driving for hours.
  16. Samimax2
    Cupcake Jan 10, 2020
    Samimax2 , Jan 10, 2020 :
    I'm very unhappy with the battery on the 6T. I just got the phone back from OnePlus who did a battery replacement. I'm down to 53% after 2.5 hrs of onscreen time. Just browsing, texts, emails, and radio.com. While I was waiting for my phone to be repaired, I used a cheap LG K40 with a 3,000 maH battery, and got all day usage doing the same things. Can someone please explain how this happens?
  17. Kytharsis
    Marshmallow Jan 10, 2020
    Kytharsis , Jan 10, 2020 :
    Two words: "battery calibration".
  18. Samimax2
  19. Kytharsis
    Plug it in overnight is the quickest.
