2
[UNIFIED] Op6t battery and heating thread
  1. G1577006622282
    Cupcake Mar 17, 2020
  2. Caomhin
    Community Hero 2020 Mar 17, 2020
  3. L1576866802549
  4. Nithinfernandes
    OnePlus Bug Hunter Staff Member Mar 17, 2020
    Nithinfernandes , Mar 17, 2020 :
    Issue can be resolved by sharing a feedback with logs and screenshots to the developers.
    Note: Your device should drain up to 30% or less before capturing the logs, so that we can get more information for Analysis.
    Steps to capture logs and screenshot
    1. Open dialer -> Dial *#800# -> Open ‘oneplus Logkit’
    2. Check ‘Move logs path to built-in SD card’-> Check ‘save log’ and click cancel
    3. Open other log info-> Click 'get bugreport info' and wait for 2 minutes(until it’s grayed out)
    4. Go back, uncheck ‘save log’-> Uncheck ‘Move logs path to built-in SD card’ and go back to home screen.
    5. Open file Manager from app drawer -> storage -> internal storage
    6. Search for Oem_log Folder ->long press it-> Click three dots on the top Right corner -> compress it
    7. Find oem_log.zip at the bottom, long press it again-> Click three dots on top Right corner -> Click Share -> Share via Drive along with the screenshot and Provide the link here
    Note:
    1. Keep the drive link open.
    2. If the battery drains most under normal use, please capture the log when you use normally. If it drains under longtime standby, please start it before you go to sleep and stop when you wake up(make sure your battery is more than 70%).
    3. After sharing the link, please delete the Oem_log file and folder from your Device or it will occupy more Storage Space.
    Note feedback can be posted by using the OnePlus Community app.
  5. Artemus.
    Artemus. , Mar 17, 2020 :
    When did you format last and did you calibrate it ever?
    drl431 likes this.
  6. L1576866802549
    L1576866802549 , via OnePlus 6 , Mar 17, 2020 :
    Formatted almost 6 months ago. pls explain what do you mean by calibration?
  7. Artemus.
    Do it again. Always format after a major version update (in this case, A9 to A10). As for calibration, drain it to 10%, charge it overnight. Do this a few times.
    drl431 and L1576866802549 like this.
  8. sahiltherockstar
    Froyo Mar 19, 2020
  9. Caomhin
    Community Hero 2020 Mar 19, 2020
    Caomhin , via OnePlus 6T , Mar 19, 2020 :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
  10. AsifurRahmanAsif
    Cupcake Mar 23, 2020
  11. Artemus.
    Community Hero 2020 Mar 23, 2020
    drl431 and AsifurRahmanAsif like this.
  12. O1584988631489
  13. Artemus.
    Artemus. , Mar 23, 2020 :
    AccuBattery is a popular option.
  14. J1585001607812
    J1585001607812 , Mar 23, 2020 :
    since the update I've been having the same issues with my battery draining.... and when I put on the battery saver it drains faster
  15. sidgautam27
    Cupcake Apr 1, 2020
  16. AjmalRasheed
    Cupcake Apr 5, 2020
  17. anil.shukla
    Donut Apr 8, 2020
    anil.shukla , Apr 8, 2020 :
    this is my 6t , it's getting heated and delay in getting charged and drained very quickly...pls suggest remedy...or ask anything else required ...
  18. anil.shukla
    Donut Apr 8, 2020
    Another full one, pls suggest as why m getting issue with the over heating & battery getting drained very fast and also taking lot of time while charging...it's behaving like a outdated one....m getting annoyed.
  19. N1540568206680
    Cupcake Apr 8, 2020
    abhis_8009 likes this.
  20. abhis_8009
    Cupcake Apr 9, 2020
