2
[UNIFIED] Op6t battery and heating thread
  1. M1571554830579
    Cupcake Aug 19, 2020
    M1571554830579 , via OnePlus 6T , Aug 19, 2020 :
    Hi,
    After updating OTA of 10.3.5 for 6T & 6 charging become very slow. Also battery Draining faster than earlier.
    Please help to resolve this issue. Now without using of my phone it took min 1.3 hours to complete 100% of charging and last till max 6 hours with normal use earlier it was more than 10 hours.
    ZATINRANA likes this.
  2. Caomhin
    Community Hero 2020 Aug 19, 2020
    M1571554830579 and sagarshenoy like this.
  3. sagarshenoy
    Gingerbread Aug 19, 2020
  4. Caomhin
    baelayet likes this.
  5. baelayet
    Caomhin likes this.
  6. ItsRavi25
    Ice Cream Sandwich Aug 19, 2020
    ItsRavi25 , via OnePlus 6T , Aug 19, 2020 :
    Try this
    For battery draining and heating issue try this.
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Thanks to @Caomhin 😇...
    Caomhin likes this.
  7. haniismayil
    Cupcake Aug 20, 2020
    haniismayil , Aug 20, 2020 :
    I have battery problem and on screen fingerprint sensor after update on my oneplus 6t 8gb varient india. The battery hardly last for 4 hrs. Earlier it used to give whole day backup. Now I feel like OnePlus is become like Samsung full of bugs and less testing before the software is released.
  8. T1590553532077
    Cupcake Aug 21, 2020
    T1590553532077 , Aug 21, 2020 :
    how to fix oneplus 6t (global) fingerprint issue
    Because it is taking 2-3 sec to open phone every time its way too slow so plz tell me a way to fasten oneplus 6t fingerprint
  9. Caomhin
    Community Hero 2020 Aug 21, 2020
    Caomhin , via OnePlus 6T , Aug 21, 2020 :
    Remove all Screen Locks, Pin, Fingerprint and Facelocks etc
    Also remove all Smart Locks as well
    Make sure you have the latest version of Oneplus Launcher from the Playstore
    Clear the OnePlus Launcher App info Cache
    Restart the phone
    See if that helps.
  10. T1590553532077
    Caomhin likes this.
  11. T1590553532077
    Caomhin
    Restart the phone
    See if that helps.​
    yes it is working faster than previous. But if there are not multiple fingerprints . Is there any other way to solve i have reset tje phone 3 days ago still it is slow . plz tell if there is another way
  12. Caomhin
    You said it is working faster after re registering your Fingerprint
    Just so I understand, are you saying it works fine if only one fingerprint is registered, but if there is 2 or 3 or more fingerprints registered it is slowing down?
  13. baelayet
    baelayet , via OnePlus 6T , Aug 21, 2020 :
    thanks man it totally helped
    Caomhin likes this.
  14. Caomhin
  15. M1571554830579
    Cupcake Aug 25, 2020
    M1571554830579 , via OnePlus 6T , Aug 25, 2020 :
    Earlier it was max 45 min. Because 6 is haveong 3000mah and 6t is 3700mah is not that big. I have reamle xt pro 4000 mah battery was charged in 35 to 40 min wil same 20w charger.
  16. PedroMagia
    Eclair Aug 25, 2020
    PedroMagia , Aug 25, 2020 :
    The my one takes the same time and is an OP 6T Mclaren Edition, Warp Charge 30. The OnePlus until now not solved the problem.
    They don't care, only want sell more.
  17. Caomhin
    Community Hero 2020 Aug 25, 2020
    Caomhin , via OnePlus 6T , Aug 25, 2020 :
    Yep, yer phone is now nearly a 2 years old design, what's the battery health like.
    Have you cleaned the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully.
  18. PedroMagia
    Eclair Aug 25, 2020
    And what is the problem that have 2 or 10 years old, the voltage of 30 watts must be always there...or when the OP make the announcement must only said 30 watts for the first year.
    Still in warranty period.
    Please don't come here to say stupid and meaningless things.
  19. Caomhin
    So you didn't bother to clean the Ports, 🙄🙄.
    Yes it should charge at 30w so long as everything is working correctly.
    Or you could also backup the phone, then do a full Erase All Data factory reset. See how that works out.
  20. PedroMagia
    Eclair Aug 25, 2020
    Bro
    I already did all these things and nothing...but the reports of WARP CHARGE problems are many. And OP nothing do.
