5
[UNIFIED] Op6t battery and heating thread
  1. R1567598838368
    Cupcake Jul 21, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 21, 2021
    Caomhin likes this.
  3. L1571723711135
  4. pablofg1978
    Head Moderator Head Moderator Jul 21, 2021
    pablofg1978 , Jul 21, 2021 :
    Thread merged
    Caomhin likes this.
  5. Spoookster
    Donut Aug 29, 2021
    Spoookster , Aug 29, 2021 :
    Same here, after upgrading to Andoid 11 the battery is draining very quickly even in battery saver mode. I even did a WIPE and reinstalled everything on the phone to make sure it's not some weird problem from upgrading from Android 10.
    Anyone else knows what is going on?
    P.S. when u saying to clear CACHE - u do that for the battery app ? or just general cache wipe with a system optimiser?
  6. Spoookster likes this.
  7. Spoookster
    Donut Aug 29, 2021
  8. Spoookster
    Donut Aug 29, 2021
  9. L1597855753035
    Cupcake Aug 30, 2021
    L1597855753035 , Aug 30, 2021 :
    I had no issue regarding the battery after updating to OxygenOS 11 (Android 11).
    Maybe switching it off and on again after 5 minutes will help. It worked anytime I had issues with my battery.
    I hope it helps!
    P.S. I believe by "cache" they are referring to what you called a "general cache wipe"
  10. Spoookster
    Donut Aug 30, 2021
    Spoookster , Aug 30, 2021 :
    I did that from recovery and nothing. There is a huge battery drainage going on and I still haven't figured it out how to stop it or what is causing it, none of the other users found the answer for it. I had to use MSMTOOL to downgrade it to Android 10. It was killing my battery for some weird reason. I wiped everything, cleared cache, did all the stuff and it just sucked the life out of it.
    Back on Android 10 and no problem.
    L1597855753035 likes this.
  11. V1565407113020
    Cupcake Sep 3, 2021
  12. pablofg1978
    Head Moderator Head Moderator Sep 3, 2021
    pablofg1978 , Sep 3, 2021 :
    Hello there,
    What device do you have?
  13. V1565407113020
    Cupcake Sep 3, 2021
  14. pablofg1978
    I merged your thread to the existing battery and heating thread.
    Please use the search before creating a new thread and check in which section you do it
  15. daweilics
    Cupcake Sep 13, 2021 at 7:24 AM
    daweilics , Sep 13, 2021 at 7:24 AM :
    I have used this phone for 3 years and have never had any battery issue. However, 3 days ago, it suddenly have a serious battery issue. The phone gets very hot easily. And the battery drains very fast. I can tell the difference immediately. I just use the app in the normal way; previously, it didn't get hot at all. Now, even the lightest use will make the phone very hot. Charging will make the phone hot too. And somehow, the fast charging seems no longer working now.
    What are the possible issues?
    And what solutions should I try?
    Did anyone have had a similar issue? The key point is: it suddenly got worse. I don't think I did anything special to the phone recently.
    (Initially posted this in the channel for OnePlus 6. Just realized I have a OnePlus 6T.)
