7
[UNIFIED] Op6t battery and heating thread
  1. pablofg1978
    Head Moderator Head Moderator Sep 3, 2021
    pablofg1978 , Sep 3, 2021 :
    I merged your thread to the existing battery and heating thread.
    Please use the search before creating a new thread and check in which section you do it
  2. daweilics
    Cupcake Sep 13, 2021
    daweilics , Sep 13, 2021 :
    I have used this phone for 3 years and have never had any battery issue. However, 3 days ago, it suddenly have a serious battery issue. The phone gets very hot easily. And the battery drains very fast. I can tell the difference immediately. I just use the app in the normal way; previously, it didn't get hot at all. Now, even the lightest use will make the phone very hot. Charging will make the phone hot too. And somehow, the fast charging seems no longer working now.
    What are the possible issues?
    And what solutions should I try?
    Did anyone have had a similar issue? The key point is: it suddenly got worse. I don't think I did anything special to the phone recently.
    (Initially posted this in the channel for OnePlus 6. Just realized I have a OnePlus 6T.)
  3. psygarden
    OnePlus TV Product Ninja 2021 Sep 18, 2021
    sujith thomas1992 likes this.
  4. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Sep 18, 2021
    Liehjan , Sep 18, 2021 :
    Try to next night charge it over night and see if battery needs optimization.
    If nothing helps then rollback or factory reset would be next step
  5. Liehjan likes this.
  6. psygarden likes this.
  7. Ankita_S.
    OnePlus Bug Hunter Staff Member Sep 21, 2021
    Ankita_S. , Sep 21, 2021 :
    We have responded to your concern via DM, please check for the same and respond with the required information at the earliest.
  8. 9923641807
    Cupcake Sep 22, 2021
  9. pablofg1978
    Head Moderator Head Moderator Sep 22, 2021
    pablofg1978 , Sep 22, 2021 :
    Thread merged
  10. hxinyu
    Cupcake Sep 27, 2021
  11. Pete3000a
    Cupcake Sep 28, 2021
    Pete3000a , Sep 28, 2021 :
    Ok give this a try. open google play store. click on your mug and go into your settings . in network preferences turn off auto update apps. Then in the play store search for google and uninstall which sets it back to the basic google app. This should work for some of you!
  12. Q1548174222232
    Cupcake Sep 30, 2021
    Q1548174222232 , Sep 30, 2021 :
    My phone used to last two days without issue but after the 11 update it barely gets me through a shift at work with all my apps are set to optimize. Was there no testing done before release? We're supposed to believe Oneplus can properly support the four devices they're determined to put out every year?
  13. domenico.raco92
    Cupcake Oct 5, 2021
  14. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 5, 2021
    Liehjan , Oct 5, 2021 :
    Looks normal to me.
  15. psygarden
    OnePlus TV Product Ninja 2021 Oct 6, 2021
  16. pablofg1978
    Head Moderator Head Moderator Oct 6, 2021
    pablofg1978 , Oct 6, 2021 :
    Thread merged
  17. L1575036286821
    Cupcake Oct 10, 2021
    L1575036286821 , via OnePlus 6T , Oct 10, 2021 :
    IF YOU HAVE DONE THE LATEST SOFTWARE UPDATE IT SEEMS TO BE A BUG THERE..... BATTERY DRAINS AND ALSO PHONE OVER HEATS AND HANGS..... AM TRYING TO FIGURE OUT WHERE TO POST THIS FOR 1+ TO ACT.....
  18. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 10, 2021
    Artemus , Oct 10, 2021 :
    ONEPLUS DOESN'T READ THESE FORUMS, ONLY USERS HERE.
    Now that that's out of the way, it helps if you could supply some screenshots of the thermals via CPU-Z and a battery graph.
  19. oskarvlc
    Eclair Oct 22, 2021
    oskarvlc , Oct 22, 2021 :
    Android system drains the battery like crazy since the 11.11 update. When the bug kicks in the battery barely lasts 3 hours of screen on time and the phone gets warm even idle.
    Rebooting usually solves the problem and it gets back to 9 or 10 hours of SOT and no overheating.
    Rebooting once a day it's annoying. More so now that rebooting takes way more than it used to before android 11 update.
